in tank fuel pump amp draw help
https://www.oreillyauto.com/detail/b/precision-fuel-pumps-4602/fuel---emissions-16775/fuel-pumps-tanks-16472/fuel-pump-strainer-16843/fuel-pump-12322/83db8e3f0135/precision-fuel-pump-module-assembly/a30060/4614935 Is there a way to figure how many amps this will draw, i need to make a harness for it. (i would also appreciate that everyone doesn't scold me for buying it as i have already installed it and i need to make some money with this truck before i will shell out the cash to go a better route)
Well i will not scold for buying the pump. I paid big bucks to Dodge for one about 9 years ago. If I had to depend on for anything but getting to and from work i would have been in  bad way. If you re using the truck for hauling for a living, you need a better pump. Just my experience.
Amp draw test.
https://www.hagerty.com/media/maintenance-and-tech/measuring-current/
A cheap Harbor Freight multimeter will work.
https://www.harborfreight.com/automotive/diagnostic-testing-scanning/7-function-digital-multimeter-63759.html
I don't know for sure but FASS uses a 10A fuse for it's system, I can't see a small in-tank pump using more than that.  You can check under the hood and see what size fuse is used for the factory pump (I think there is one in the PDC for the fuel pump :think:).  The only true way to know is if you can connect it up and run it and check it with a meter like IBMobile said.
