- Replies 29
- Views 15.5k
Yes that will work. The trigger wire is the yellow with white tracer that was used to power the factory lift pump. That goes to terminal #86. Red power wire to terminal #30. Green grou
I don't think you can get those connectors separately. You can make your own connection using insulated male and female spade connectors like I did below.
I bet @Me78569can tell you where to get a plug like that
Hey guys began installing a fass TS 165 on my 01 tonight. Just wondering where I hook my wiring harness to start my lift pump. My instructions say hook green and red to battery terminals (did that) then says plug into the oem lift pump harness but my only other connector on the fass harness is a small red wire with a fuse tap. Can I solder this red wire into my oem lift pump harness or do I need to use the add a fuse? Other then hooking up this wire my install is done just waiting till daylight in the morning to finish up. Thanks
