1998.5-2002 guys with a swapped in Manual transmission
- Replies 11
- Views 8.1k
paradisepete 3 posts
leety 2 posts
wil440 2 posts
Joshschneids 1 post
Welcome back to the forum and thanks for the update. My truck is a factory manual but I've noticed plenty of people swapping auto's for the manuals so I'm sure they will appreciate it.
I LOVE the manual stall prevention. I never slip my clutch with an empty truck. I can just let it out fully in second gear then add fuel. I can do this with my big trailer attached. Only when I ad
Sorry.... I got to ask..... are you selling the auto ecm and pcm by any chance
Hey all, I have been a member of the forum for years but have slowly moved away from it over the years. I am back now and starting to toy with my truck again. Wanted to make a quick post for guys who have either swapped/ purchased there truck with a Auto to Manual swap. I did mine 2 years ago and have been running flawlessly since then.
Now to the point of this post. I never swapped my ECM+PCM during the swap because i never had any issues. So why swap the computers if you don't have to right? (I am kinda one of those guys if it works don't F*** with it!).
So here we go i was definitely WRONG. If you have done this Auto to Manual swap and not re flashed/ swapped computers i strongly recommend doing it and here is why. My truck was always a stall easy truck since the swap and i would have to rev up quite a bit for a 2nd gear start and always be feathering the clutch at every intersection hoping for a smooth start. It always felt so easy to stall like no governer almost. (also have a full ceramic SB DD clutch) The truck always rev'd higher at idle due to no automatic trans bolted to it anymore. Almost 900RPM. I had it in my head that the factory Manual trucks would run somewhere around 800RPM idle instead of the 850 that auto trucks did.(Think a post on this site lead me to that info) also i figured i would get some sort of Anti Stall software built into the computer also.
Anyways i swapped the ECM+PCM yesterday and what a difference. Noticeably quieter (lower) idle and the truck has anti stall software now. This truck is a totally different truck now. I can leave intersections and pull out in front of people with confidence. In cab the only difference i have noticed is the gauges do not light up trans temp on startup for 5 seconds or so anymore. The Manual PCM swap got rid of that. Just a FYI i am still running the factory Auto wiring harness and have no lights or any issues so far. Just wanted to make a quick post and say if you have done a auto to manual swap and have not matched it with the proper computers i strongly suggest doing so! Josh
Oh yeah i just bought a Quadzilla Adrenaline. I have been running the Comp for years and Mopar1973man's move to the Quad made my decision to switch and i am excited to get it in the mail . Josh
Oh yeah one more thing. I have also noticed that my Fuel pump only runs for about 1 second if that with key on before startup and the auto computers would make it run for 3 seconds or so maybe then shut off.
