- Replies 20
- Views 4k
Evan 8 posts
Mopar1973Man 5 posts
Dieselfuture 3 posts
Haggar 2 posts
Evan, Just rebuild it. IF you can't find a complete rear, just yank it apart and rebuild. It goes easy. just heavy. The only special tool is a good case spreader (and a dial indicator and mag
That's why I was asking about learning here. I really trust you guys for info but randomly watching YouTube can be risky like watching a YouTube about tightening a 5th gear nut with chisel and hammer.
I did watch about 40 minutes of this new vid that popped up in my feed. Guy does a very good job of explaining what hes doing and why. And the wrench to remove carrier. Why didnt i think
Replaced the seal on my truck while the driveline was being rebuilt, was pretty meticulous about prepping the surface and using rtv to try and seal everything. Got the driveline back installed and took it for a drive and is leaking worse than before. I used an impact to remove and re install the pinion nut and used a new nut. I’m wondering if maybe I got the wrong seal? Through my reading I think there is a flanged and non flanged yoke, and I thought mine was non flanged. Also wondering the removal process for the breather tube as thinking that could be part of the problem. Thanks
Also I used a speed sleeve on the yoke to repair the pinion sleeve and this is the seal that I used mopar 5015618AB from rock auto
