2006 Transplant no start
HELP!!! I've tranplanted a 2006 HPCR into a 2000 Ford Excursion 4x4 with an Allison 1000 5-speed and I CANNOT get it to fire. Anyone got any ideas? I had Bob Wagner (Smarty) program the ECU to shut off the SKIM requirement and make it into a "stickshift" so I can run the Allison TCM as a stand alone. I have 90hp injector tips, a modified cam and have bypassed all the wiring I can think of just to eliminate potential problems so I can get it running, but it simply will NOT fire without a shot of NO-NO fluid, but will not keep running. Once the ether is gone, no fire, period. Also, it appears that the oil pump is losing it's prime if it sits overnight and won't pump oil up to the rockers without forcing oil into the turbo oil feed tube first. Any ideas and suggestions short of shoving it off a cliff would be appreciated. Thanks in advance- steve "dieselclam holmes
  • Replies 16
  • Views 3.7k
Grid heater working??? RPRV OK??? CP3 making enough PSI to start??? Fuel in the tank????You said injector tips. Tips are fine on good injectors. How many miles on the injector bodies before the new tips????Provide more info if possible.:smart:
Get a scanner and watch the rail pressure while you are cranking.Also get a manual oil pressure gauge and plumb it in to verify oil pressure it takes a few seconds of 700-800 rpm to get the oil pressure up, but you're not really gonna have any just using the starter crankin on it.
Like I tell everyone it time to get basic to basics... What is required of a diesel engine to run? 1. Fuel2. Compression So is the fuel rail getting pressure? Any air in the fuel? Grid heater is not a huge requirement to make it start but it will help... You might baby it by plugging in the block heater... If the block heater is plugged in you can un hook the grid heaters and give a small burst of starter fluid and see if it pops... If so you know you got good compression. So then I would double check the ECM to be sure it getting power and coming online to fire the injectors...
What kind of wiring bypassing have you done?There is very little you can bypass on these HPCR's and make them run. I would guess you have an issue with the HP system, whether the ECM is telling it not to fire for a missing/loose connection, or a bad FCA or Injector. I would pull the injectors and have them tested, then start looking at the CP3. A Stage 1 Bag of Parts will change out all the common problem parts with high performance ones, so that may be a place to start if the injectors test good.
:banghead: 1) You cannot make a Freightliner configuration engine think it's a Dodge because the tone wheels for the crankshaft and the cam shaft are in different locations. Time to buy a grossly overpriced, remanufactured and reprogrammed CM-850 computer from Cummins because the CM-849 just ain't gonna work.2) "a few dyno pulls" means that they pulled the rings right out of the engine so I didn't have enough compression to even light the fire despite how good the cylinder walls look.3) My rule of thumb for how long it's going to take to finish a project (2.5 times my best honest guess) is not obsolete but ancient history. 4) Injecting methanol into a diesel engine will make it run great for only a very short and very expensive amount of time. A belated thank you for the suggestions.
Lessons aside, where do you stand, now, with getting it to breathe on it's own? Or is it, already?
Ok thanks AH641ID and Guesswho512 what kinda pressure do these run??? DieselClam did you get it fired up yet???
IIRC, ~+20,000psi off idle at the rail. -=- edit -=- Found this tidbit..
Idle you should see 8-10psi off the lift pump. Running down the road should be 4-6psi, at wide open throttle as long as you have some pressure your ok. Now the rail pressure is a different story. . . The rail itself should have about 5K at idle, 12-16K normal cruise, and at wide open throttle you should see it rise to as much as 22K but level out around 20K-ish.
HOLY CRAP thats alot of pressure!!!:stuned: so what does the VP run for pressure???
The 5.9 HPCR is capable of just over 23K, and the 6.7 runs about 26K max. IIRC the 11 dmax runs around 30K.
