hey guys n moparman, first post here i just got an email from the site suggesting my return but ive yet to post anyways ill start off with a bang..
01 24v dodge excab 4x4 stock new vp n raptor, 86mph 2250 rpms i think forget what its governd to also have a 12v anywho pedal to the floorboard 13 psi going to the pump. idle i think 14 -17 im pretty sure. im trying to do this from memory i havent driven the truck in a week or so.
so i believe it gets good FP? the gauge is taped into the shrader valve on the fuel intake banjo bolt and i recently changed the fuel filter and saw no change in numbers... regardless the truck gets 11-12 mpg around town. litterly $100 or about 22 gallons of diesel goes 250 or less miles...horrible i have 17* of timing in my 97 12v n it gets better mpg.
on the bright side...winters rolling around and my coolant temp gauge is pegged on 140 and that truck doesnt get warm for sh*t...is it as simple as a stuck thermostat? im a 12v guy i no nothing about vp44,obd2... all i no is the map sensor also went in this truck and it was close to $500 no one could get it but the dealer so i dont want to have to buy anymore sensors and such...i would like to sell this truck, but of course i want to get the kinks out. thats why im here pickin you guys brains, see what we come up with. Also i dont know if this forum offers a for sale section or not i havent looked around much but i got a decent deal on this truck i believe so if anyones interested there might be another good deal to happen?! thanks all.
ps- i did not proof read.
  • Replies 31
  • Views 5.2k
pulling a 16k load in 110 degree heat it probly worked,especially in the hills.:woot:
I doubt it! Even in hot hot days I haven't ever seen more than 10° above full open on my thermostat. So even if we assume it got 20° above full open on a 130° stat your barely to min operating temp and that's only going to be on long hills. The hardest the cooling system gets worked is in 6th gear, rpms are low, EGT's are high, airflow is down, oil is hot, and torque is high. As you gear down you reduce the strain on the cooling system, and at 24K+ gross hill are probably pulled in 4th gear, maybe 5th on small hills and you just don't have the strain you would at 18K GCW in 6th. I can't think of a single good reason to run a 130° stat!
Then WHY does someone manufacture one for this engine?:shrug:
I cannot find a part number for it, but if it's made it is possibly for a different ISB, maybe even a natural gas version and a special application. It is not intended for any pickup motor.
Even pulling a 8K trailer in 110*F outside temps with a 190*F thermostat wasn't bad at all the temp got up to 205*F... No big deal here... :clap:
Maybe you should try 16k lbs then! I bet it gets hotter.
Low thermostat likely has other applications. I'm familiar with marine engines, particularly Raw water cooled... salt / seawater would salt up at higher temps. I F'ed up a plow jeep with a marine thermostat... The next owner replaced the T-stat & all was well. Duhh!
  • 2 months later...
Bringing up the old thread. I was recently reading some info on low temp after-cooled QSB's, they have a 165° thermostat in them, and the min full load operating temp is still 160°. I still can see where a 130° stat would be used on B series diesel motor, it must be a natural gas application.
I wouldnt mind a 200 degree tstatI swapped my oem out with a 170/175 (forget) .....but thinking going the other way (200) for non towing would help with mpg :shrug:
My mpg's went up nearly 4mpg when I got my truck out of the 150-170 range and back to 190.:thumbup2:
For real ?? wow tstat ??
