Replacing the VP44 Injection Pump
Don't worry... There is no way to pick up the gear enough to actually move it... Someone from over at CF did the testing and found out the only way you could actual do it is take the gear case cover off. Other than that you can't lift it high to clear the gear teeth... So slap the new pump in! :wink:
:iagree: It's in there too close to have moved.
I was gone (from here) a couples. Anyway the help is great and everything seems to be solved. I erased the old code and don't have any new ones. The truck runs great.I do drop in and read stuff at least a couple times a week. I just don't have a lot to say. It's better to read a learn. Thanks again.
Thanks again.
Make sure to take the time and ask questions... :smart:
