I just found this forum from CF, I am trying to solve the TC unlock issue with out doing all the band aid tricks- foil, extra grounds, wiring gadgets, re-wiring, Etc. My truck has the 45-50 tc unlock issue and the 4th gear hunt.I started by cleaning the battery terminals and the grounds on the alternator. The best solution I have seen so far is the conversion to a 1 wire alternator, the guy who tried it took of all of his band aid tricks and the problem did not come back, the theory is the voltage regulator in the pcm is interfering with the apps circuitry.Since I don't have 300 for a new alternator I want to try to install a external voltage regulator. I saw a thread on here about how to install one in a first gen when the VR in the PCM fails. Has anybody installed one and had success with the TC lock issue, AND/OR the 4th gear hunt?
Mark,Have you tried pulling the 140 amp alternator fuse? That will tell whether or not your alternator is the faulty part if that stops it. If it keeps going, check your batteries. Take them to Napa or similar store to have the alternator bench tested and also the batteries if the alternator turns out to be good.I had the same issue exactly, pulled the fuse and it went away. Replaced the alternator and it was fixed for a bit, the new one went away after a month, it has been replaced under warranty.In ready Moparman's study of this issue, I agree with him about an alternator causing a lot of problems as it is connected to just about everything in your truck. A faulty alternator with a bad diode could be suspect in alot of other equipment failures not to mention a VP 44 or others. You might read Mike's information, think on page 1 of this thread.Good luck. I too am new to this forum and have learned so much, these guys do know what they are talking about and they don't give you a bad time for not knowing much. They are a tremendous help.
Mark, Have you tried pulling the 140 amp alternator fuse? That will tell whether or not your alternator is the faulty part if that stops it. If it keeps going, check your batteries. Take them to Napa or similar store to have the alternator bench tested and also the batteries if the alternator turns out to be good. I had the same issue exactly, pulled the fuse and it went away. Replaced the alternator and it was fixed for a bit, the new one went away after a month, it has been replaced under warranty. In ready Moparman's study of this issue, I agree with him about an alternator causing a lot of problems as it is connected to just about everything in your truck. A faulty alternator with a bad diode could be suspect in alot of other equipment failures not to mention a VP 44 or others. You might read Mike's information, think on page 1 of this thread. Good luck. I too am new to this forum and have learned so much, these guys do know what they are talking about and they don't give you a bad time for not knowing much. They are a tremendous help.
I did read the part on bad diodes in the alternator causing a/c voltage leaks into the system but I have read stories (on CF) of people replacing the alternator more than once with still the same problem, I like to look for fixes that no else has tried because we have not found the magic bullet yet. Right now I suspect that even though the alternator field circuit (from the ecu) is not tied into the A/c generator circuit, the generator's a/c electrical field could be inducing voltage or RF noise into the field circuit. Over time the ecu becomes more likely to be affected by interference due to heat cycling and ground connection degradation. If I completely disconnect the interference from the ecu it may stop affecting it. Or at least that is my theory. I would like to say mopar1973man is pretty cool for giving out all the advise that he does:thumbup2: and the people here seem to be pretty smart, I am a technician and this is the type of problem that causes me to loose sleep. I think we are close to the solution and if I find it I plan on sharing it as much as possible.
I tightened/ cleaned all my battery terminals. The grounds were so loose I could turn them with 2 fingers. I installed battery post shims and that works great. I also checked the AC volts at the battery; 30 VAC and just under 14 VDC. I don't remember if I checked it before I tightened the posts, though. I will check it again with the terminals tightened just to see what it is at.I also cleaned the grounds going to the body on each battery and the ECM ground.So far this has fixed the TC lock/ unlock issue for me. :hyper:
Well Guys, I am another one who is having this issue. Just bought the truck a couple of months ago and really love it. The only thing I have done so far is pull the neg battery cables off and cleaned them a bit. It did work for a few weeks but has come back.It does not do the lock unlock issue all the time. So my question is if I pull the fuse for the alt, how long can that be left out? I am not a motorhead or a whiz at mechanics. I can do a little bit, but this might give me more grey hairs :banghead: I also just got to thinking.........Love the truck.......but I am wondering if I need my head examined :cookoo:Thanks!Rob
Not extremely long 10-15 minutes driving at most, turn off everything electrical try not to use the brakes (brakelights) I once drove a car with no alternator belt for a half an hour (emergency situation) I had to recharge the battery to get it start once I put a belt on it. But I would not recommend driving for that long.
Hmmm, that will make it tough since its an intermitten problem for now. Thank you for your reply. Rob
Just tryed the 140 amp fuse test myself and the second the torque converter locked the computer threw the check gauges light and the voltage dropped like a rock so I pulled over real quick, After I hooked it back up the voltage was ok the batteries had not drained Going to try again later and ignore the stupid light and gauge.
  • 3 weeks later...
I was reading on Cummins forum and someone had added a ground from the pcm(passenger side of the firewall) to the negative terminal on the battery. I added this wire to mine about a week ago and have not had the TC issue once since installing the wire. Just to be sure I unhooked the write before leaving work today and the TC issue was back within a few miles. I pulled over and reconnected it and had no more problems the rest of my drive. Might be something to consider trying. Sent from my DROID BIONIC using Tapatalk 2
I don't know too much about electrical. Couldn't a guy take a portable radio, while the trucks idling and point the antenna at different areas under the hood to find the source of the RF noise ? I don't really know but wherever the loudest static comes from would be a clue?This is quite possibly the worst suggestion on the forum ever:cookoo::shrug:
  • 3 weeks later...
Hey guys,Was thinking of pulling my alternator fuse for the drive home after work today..2 questions, where is the fuse? Is it obvious to find? IE - diagram on the underside of the fuse lid like most vehicles?Second, my drive home is about 30 minutes.. am I risking any damage having the fuse out for that long? If someone could give me an answer in the next ~20 minutes, that'd be great!
Hi Guys,Tons of good info in this thread (site too!). I know I'm new but I want to add a little info I didn't see that might help. If its already mentioned, please disregard. I'm seeing there is a little confusion between voltage regulators and rectifiers. The voltage regulator in the ECU is what controls the amount of DC voltage from the Alternator (simplified explanation). The rectifier in the alternator is what takes the AC the alternator makes, and converts it to DC for the vehicle to use. This is the part with the diodes that go bad. They are two different animals. Using an external Voltage Regulator wont solve the issue, as its not the cause of the issue.I think the only way to solve the AC/RF noise issue is to rebuild the rectifier with higher quality components. I don't have the cash to get a new alternator and tear it apart to research more, but I'm pretty confident that if higher quality components are used we'd have great results.Thanks,Travis
Just wanted to update I checked for ac voltage at the batteries and at the 140 amp fuse, the highest it showed was .026, one thing I have found is when the engine is off the throttle position reading on my scanner is steady when the engine is running it jumps up and down slightly, it showed the same result with the serpentine belt on and off.
So after giving my input I decided to go check my new-to-me 99 to see if there were any RF issues. I haven't had any TC issues, but I wanted to check anyway as I've only had the truck a week.I'm not sure if I'm glad I checked, or sad. 120v AC. OUCH! The PO had changed the alternator and foiled up everything in sight. I'm going to add another ground to the alternator because I think its a good idea anyway. Does anyone have a bad (AC issue only) alternator they would be willing to send to me? I want to take one apart and look at the rectifier to see if I can build a better one. I will do a writeup and post it here. I will send you back the fixed alternator once I am done testing.Travis
hello all,I stubbled across this TC lock/unlock forum while looking for the answer to this problem, I have read all the patch fixes, etc. and this fix seemed like the most promising. I have a 2002 Ram 2500 Cummins, auto trans, about 120,000 miles. I cleaned all the terminals then removed the 140 amp Alternator fuse, the TC issue seems to go away as described with the alternator out of the equation. Then I removed the factory alternator and had it tested, on their machine everything passes, I then asked for the details of the test and noticed the AC Ripple Voltage was 0.2v, which I know is higher than the 0.1v ideal per this thread. I then asked to test a brand new alternator prior to purchasing it to see if its AC voltage was lower and it tested at 0.3v, so I did not purchase it and am basically stuck at square one. Any Ideas?Thank you,Josh
