- Replies 22
- Views 5.3k
VectorG 10 posts
98whitelightnin 3 posts
Mopar1973Man 2 posts
hex0rz 2 posts
Well on the Suggestion of 98whitelighting, i lurked around searching on here for what my issues may be but to no avail i didn't find a solution to my problem. As of 2 days ago my truck was running just fine, then my CEL came on i went to parts store scanned and came back with P0237 MAP truck ran fine though so i cleared, came back about 6 hrs later cleared again probably coming on because of my XZt+ i had just uploaded a new tune to it. I don't know if this coincides with my issues from today, truck was driving fine this morning went to pick up a load for our job site and on the way back cruising about 35MPH truck just shut off, I checked fuel canister had bout half canister i topped it off, had plenty of fuel in the tank. tried cranking for about 5 mins to no avail so i had it towed. As to that point i searched all over Cumminsforum with no luck to my issues, so i figured id try over here. i have unplugged the XZT+ checked Batts, unplugged APPS and reset tried jumping the MAP Could a bad MAP cause a no start? i dont have the socket to take it out at the moment to clean. i can hear my LP buzz for bout 2 Secs when key is turned on no start like normal. Only conclusion and can come up with is maybe my VP is shot? ive checked fuses/relays all connections still just turns over. And i haven't installed a FPG yet i know thats a first for these trucks i just havent had time with work very busy lately. I'm sorry for such a long post im just trying to cover every issue that has happened and step ive taken to resolve. Any help or input would be greatly appreciated. Thanks
