apps
my truck threw the codes p2121 and p2122. Now it is back to acting fine, I dont really want to get stranded anywhere again so should I just order the sensor? And whats the deal with someplaces you get the whole bracket with sensor already in it, but other places you just get the sensor and you might have to calibrate it. The price difference is huge but which would be better?
To the OP, you've got a 3rd gen, correct????? If so, do you know which APPS you have?????They can be mounted on the engine in front of the intake horn under the bell shaped housing, they can be under the drivers side battery tray (like mine), or they can be on the floor inside the cab connected to the go pedal.You'd better find out before you order, as they are not all the same in a different location.
To the OP, you've got a 3rd gen, correct????? If so, do you know which APPS you have????? They can be mounted on the engine in front of the intake horn under the bell shaped housing, they can be under the drivers side battery tray (like mine), or they can be on the floor inside the cab connected to the go pedal. You'd better find out before you order, as they are not all the same in a different location.
Ya mine is mounted to the engine so it should work :thumb1:
What is an apps? And does my '06 have one? Tell me, tell me now. LOL
APPS=Accelerator Pedal Position Sensor Yes; your '06 does have one. It'll either be under the drivers side battery tray, or in the cab connected to the "go pedal". Only the early 3rd gens had them mounted on the engine under the bell shaped housing.
