What's Best For Our 53's?
- Replies 35
- Views 7.1k
Texas CTD 9 posts
Mopar1973Man 8 posts
fire176969 4 posts
ISX 3 posts
So after reading more about high idle, and 3 cylinder high idle, I kinda got to thinking about what is best for the 53 block.I always let it warm up to operating temp before driving, and if I have to just cruise around the pasture, I'll let it run for a minute, and then I'll start to drive. (1st and 2nd gear, not getting above 1,300-1,400 RPM) If I'm in a hurry, I'll let the temp get to 140*, and then go easy on it.Here in SE Texas, I'll probably never start the truck below 20*F, so what is the best warm up procedure in those temps? Is a rapid warm up better for a 53 block? I know if it idles too long without the coolant temp rising, there can be some damage, but I don't think it gets cold enough down here for that to happen.Last winter, most of the time I was starting the truck between 40*F and 60*F, and would have a 10-11 minute warm up. If I had nothing to do, I would do a "manual" high idle,(hold the pedal, and put about 1,100 on the tach) and that would decrease the warm up time by a minute or two. With that said, my question is, which warm up procedure is best for the 53?
