HELP! Leaking injector!
If it is pumping fuel out to where it is running off the engine you have a leak, if it is just damp with fuel it is just fuel that was trapped in the void in the head between the line nut and crossover tube and will weep out and dry after a few days of being warmed up good. Very common and nothing to worry about happens all the time and folks think they have a leak which they do not.
When I installed mine I tightened the injectors and then installed the cross over tubes and had more than one leak. I went back and reversed the order. Installed the injectors then then crossover tubes, tightened the fuel lines and then tightened the injectors and all my leaks went away. That said I think I would put on new o ring on and see if that stops it.
