Anyone here a woodworker?
- Replies 16
- Views 4.7k
hex0rz 5 posts
JAG1 3 posts
joecool911 2 posts
MoparMom 1 post
Ugh, this is frustrating. I was never a woodworker by trade and have pretty basic skills when it comes to that sort of thing. I was hoping to see if anyone here knows what my problems could be...
I'm getting my butt into gear and trying to get my beehives built before mid-april when I'm supposed to receive my bees. I'm buying 2x8 lumber and ripping them on end to make 1x8 out of it. I'm trying to make sure I get clean cuts as possible but there are a couple issues I'm running into.
I've been borrowing the in-laws table saw, its a cheap 10" portable skil table saw. When I mean cheap, I mean cheap. I'm disappointed in SKIL! I've been able to manage to make it work alright so far. Definitely triple checking the fence for straightness.
I presume the blade they had on it was the original that came with it. Piece of junk, I almost went deaf using the dang thing! So, I broke down and went out and got the DIABLO brand blade. I believe I got a 40T blade and then got an 8" dade blade set as well.
So, I'm having two problems:
1. When I'm trying to rip these 2x8's on end, I cut them to length first and not rip the whole 8' at once. I realize warpage is a risk here. But even then, my pieces range from 16-19" in length. Which I would not see being too much of a problem. I'm putting the pieces on the saw and ripping them a little at a time. Every pass I make I raise the blade a few turns then cut again. With this saw, and the height of the wood, I'm still left with about 1/2" of wood in the center that I cut out with my sawzall.
Except, when I start ripping these pieces, I dunno whats going on. Its like one moment the blade goes straight and true into the wood and I'm making the cut center on the board and then the next it seems to cut a different direction! I dunno if this is due to the saw, the blade, etc? Its got me confused.
I've also noticed that the lumber I bought is from the local sawmill. I used to work at one of their locations so I know they kiln-dry the wood. But heck, by the time I get all the wood cut I can before I use the sawzall, it seems like the board is cupping really good. Could it still just be too wet?
I had some 2x8 from a year ago that I used first before I went out and bought more so I could experiment with it and they worked real well. I'm not sure I could say that they were any drier though? Still had some cupping action to the board on them as well.
2. So I have to make some dado cuts and I just cannot explain this one either. I have only one idea of what it could be. The saw never came with a dado plate for the deck. So I had to make my own out of some 1/8" board. It sits nice and flush and works great. Except, being that it is so thin, it flexes. When I take my piece and dado cut it, from one end to the other, the cut is somewhat wavy and the ends have cuts deeper than the middle.
The middle is the proper depth cut, but the ends have deeper cuts. Now, to me that seems that the plate I made is flexing as I cross it to make my cut? But I still cannot explain why then it would be wavy? I made my dado cuts on the pieces this evening before I ripped them and the problem is virtually gone. Its not perfect, but very close.
At this rate, I'm getting more and more serious about getting myself a better table saw. A man just cannot work in these conditions! Time to talk to the boss...
ALSO, would I be better off using a 24T FTG ripping blade instead of the 40T blade? I've been trying to get as clean a cut as possible when ripping it, and its not bad, but I don't want to have to try and beg for a saw AND a planer!
Anyone got some input on this? I really try and do the best I can with what I've got, but this is driving me nuts as I tend to be a perfectionist and I would hate to have someone look at my hive and tell me how ugly they were. Although, atleast I know the bees won't care, and I will have my honey!
Edited by hex0rz
