Hello again all,
Howdy folks been awhile since i logged in but just got back from our first trip to our favorite campsite on the lake. This was the first time going to this site with this camper (This site is the farthest and has the most hill's and curve's).
So i'll put the info up on my setup:
Truck:
2001 Dodge 3500 ex.cab LB Dually 4x4
5.9 HO Cummins 24valve 6 speed 3:54 gear's
Upgrade's:
Motor wise BHAF, Aftermarket intake horn, Fass 150gph Fuel pump, Bank's Big head wastegate, of course EGT, Fuel pressure, Boost gauge's.
Tranny wise South Bend 3250 Dual disk clutch, South Bend Upgraded Slave/Master cly.
Hitch: Reese fifth Wheel Rail's with Reese 30k Gooseneck adapter hitch
Trailer Hitch: Bulldogg 26k 5er to Gooseneck adapter
Trailer 1998 Newmar moutain air 39BRSK 40' Dual tandem rear axel's with front and rear brake's, Total Trailer weight 18,000pd's (Can provide pic of build sheet if in doubt it does weigh that much when fully loaded for a trip)
So to get to the point the truck can stop the trailer with ease (With and with out the trailer brake's on found that out by accident wire got pulled out of fitting). And taking off from a dead stop both on flat ground and on a hill is not a challenge my real issue is getting up to 55+ when getting on the interstate or just getting to speed at all. The drive from my house to the lake is about 30 mile's one way 80% is 6% grade up or down and 90% curve's( if you've ever been to kentucky you'll understand...)But after 3rd gear my egt's climb like a jack rabbit... from 800F in 3 at 35-40mph to 1150 in 4th at 45-50 mph at 30PSI boost. after i get to 55 i stay n 5th gear i know to stay out of 6th but, on most hills i got to drop to 3rd and by the time i get to the top i'm crawling to a point around 35-40 mph since it's about a right or left turn at the bottom of the hill going up. I was hoping for some insight into what to buy next injector's, Twin turbo's, intercooler, tuner??? there's so many ways to go what is my best route with this setup and it will take time as i'm alittle short on cash after the camper buying and all lol
on a sidenote the original owner who sold this camper to the dealer i got it from who then put me in touch with him bought his camper and truck the same day in 1998 for the last 15 year's he pulled this monster all over the south with a 1998 dodge 1500 excab LB 4x4 auto 360 truck...which i said BS till he showed me a few dozen family photo's of them all over the place... this man was insane my dually cummins now's it back there for a fact he was either nut's or had brass nut's to do that with a half ton but he never once had a moment's trouble...
post-1211-0-67603800-1396842880_thumb.jp
post-1211-0-14365300-1396843585_thumb.jp
Edited by GreenRiverCummins
  • Replies 54
  • Views 12.7k
That  guys  RE  automatic  must  be  a lot better than all the RH's  I've  burnt up over the years!
It would be nice to have current weights of both the truck and trailer. (Fully loaded).
Me personally found that a Edge Comp module and small injector like RV275's or +50HP are very controllable. Even with the Edge Comp on 5x3 the EGT's are controllable and gives good performance. I'm still running BHAF, Straight pipe 3" exhaust and a HX35 turbo. I typically gross out at 17,000# but that's a far cry from your trailer weight. This why I was asking for current weights with water and everything.
I would agree with finding a timing box. A timing box plus a boost elbow and you should be able to get your EGT's in check a lot easier.
Think that SBDD clutch is around 650 hp.
Intercooler is fine.
You really only need something similar to mike. At least to start with if funds are tight.
Edge Comp(or old juice) ~  Box $350 used.
RV275 or +75 HP injectors - CPP or DAP. ~$350 new/rebuilt.
If you want cheaper - then get a powerpuck instead of comp box and go with ~100Hp sticks. Save around $200 more.
I would have to agree with everyone else edge comp and injectors just don't go over 75hp with the stock turbo. That setup should put you where you want to be.
Cool thanks for the info y'all and sorry i took so long to respond work has been heck this week... And i would like to get a total weight on the Truck/Trailer if i knew where i could do that at? But i will check into getting a Edge and some of those RV275 injector's soon. I plan on taking this pair to piegion forge in the next year and i know it would be unsafe to get down there and have it get to hot exhaust wise. With all those big hill's and all thanks again
You can find a scale at most larger truck stops or maybe at a feed mill. Sometimes the state weigh stations will leave the scale and display on after they close and you can weigh there too.
Just got to look around.
I know where all the public scales that leave on the display like one in Horsebend, ID. Or the Shell station in Council, ID just ask the cashier and they write down your weight. Or my other favorite in Grangeville, ID there is a feed store that leave the scale display on 24 hours. I try to check RV/Truck weight twice a year.
Thanks for the info will get on that and also I have been looking around to see which is the best way to go about Strut's/Shock's on the truck the ride is getting rough and is bumpy at times with this size camper which brand/style would be best. Also I had an 06 Mega cab that came with Rear airbag's and they were great when hauling a load of 14 2k rolls of hay on our gooseneck would keep the load level at all time's and the ride was amazing for a dodge again which brand and size would best fit my truck/camper set up they need to be strong for this kind of weight Thanks for the info and all the help thus far
Try:
http://www.airliftcompany.com/
http://catscale.com/cat-scale-locator/map
^Depenind on where you live, you may be able to find one.
I think a good tow rig needs to be able to get the load going, get it stop, safely, and handle the load.
Look into an exhaust brake. Good thing about that, you have a manual. So that should not be into more than $1k for one.
Look into bilstein shocks. I also hear ranchos may be good. Look into timbrens for bumpstops.
If your shocks are worn I would get them replaced. I've got Bilsteins all the way around, big improvement over the old worn out OEMs.
My personal preference in load levelling would be air bags. Timbrens are good for slide in campers or guys that are loaded all the time but anytime you run around empty the ride is horrible. I have a friend that runs them on his Ford, I don't know how he deals with it. Every time I'm in that truck I need to see a chiropractor.My airbags also ride a little rougher when empty but aired down to five pounds it is acceptable.; I've been contemplating piping in a set of ping tanks to help with the ride but I haven't decided if it's worth the money.
  • 2 months later...
Thanks Michael, do they still make the Edge Comp or something similar?
Thanks,
Dave
  • 2 months later...
Personally I would go with 60-75no injectors and a smarty.
I have rung out my truck and the 100's can be warm at times but I also can say the larger injectors, and the tm on the smarty make a noticeable difference.
If you want find 7 hole injectors for smoke control and a boost elbow for extra boost.
How does a different boost elbow give more boost?
there is  a adjustable  valve in them, Uses  a  little  allen wrench,    which   adjusts  the  waste gate opening.   My guess is it lowers  the  'felt' pressure  by the  waste gate...  (keeps it  closed)  which  will  give more  boost
I'm going to suggest a different route and say gear swap!!!
If your already at 30psi and 1150° adding hp isn't going to do much but add heat and you don't have a lot of room left for more air or fuel. I am surprised you are pushing 1150° with stock fueling and 30 psi thou. You might be able to squeak a little more power out, but you won't run cooler.
4.10's will give you an additional 16% torque to the rear wheels.
I haven't seen the pic's but I'll call BS on the 1500, the rear tires wouldn't hold the weight nor would the axle.. let alone the frame or suspension. Could it have been a 2500?? Same body panels.
