Little puff of white smoke when starting
I'm assuming I'll need valve seals. Any way to do it without removing head or injectors? If I could figure out where tdc is for each cylinder valves should not fall in. Lol. #6 hard to do?
Edited by joecool911
  • Replies 13
  • Views 2.8k
My 98 would puff white on cold starts too until I switched to a p-pump, could be something other than valve seals.
Like what? Approaching 200K miles.
Idk, my truck had 260k and the little puff bothered the heck out of me. I pulled the new injectors out and sent them back to contagious to have them checked, they sent me a whole new set and it still had the puff.
When to be a bit concerned is when the little puff of smoke smells like engine oil. Then you have oil leak. If the puff smells like fuel then you most likely have a injector issue.
is it every start up, or  cold only?        typically a  valve  seal  needs  time to  leak down,  so  an immediate restart  should be clean....    But on the other hand,  a hot piston will mask a pissy injector too.
....... pretty hard to race around and  smell that elusive  puff...  Pretty windy around here lately! :)
Should have  a blue haze  if it's  oil,  but  the sun  shining from different angles  can  change  the color big time.
Lots of  definitive answers in my post!    LOL
I was thinking about running a hose to the cab so I can diagnose exhaust smell ;)
Don't forget to take pictures when you do!!  :lmao2:
  • 3 weeks later...
