01 dodge speedo doa
OK John...
Using the wiring diagram above...
http://forum.mopar1973man.com/index.php?/topic/9846-01-dodge-speedo-doa/page-3#entry109062
I ohm tested my truck. Now just pulling the connector from ABS controller and probing the plug (Red/Violet & White/Violet)
With sensor hooked up ----------------------- 1,838 ohms
Without sensor hooked up and shorted ---- 0.006 ohms
Re do your test.
Sent you a PM.
Im not sure what the other test is ...... but basically
Remove left side ABS controller.
Pin out the top right and bottom right pins with multimeter = 1.9k ohms ....... Im assuming the pin locations are the same for an 2000 ........
Thx for call and dumbing it down .....
I shorted the circuit at rear .... measuring 0.008 or basically 0 also
So both measurements same as yours .....
Will work on pulling the rear diff and servicing as well as the ABS and report back.
2 steps backward .... 1 forward
Got the abs rebuilt .... But I busted a bolt off into pump block due to rusted.
Drilled it out and started rethread .... then the tap busted and it's hardened steel... can't drill it out with bits I have.
so unless anyone has any ideas on getting busted thread tap out ..... think I'm going to have to buy a abs pump.
Most taps are made brittle enough so that you can break them up by hitting them with a punch and hammer if they break off like that, in my experience it doesn't always work out that well but could be worth a shot.
Edited by bjytech
Is there any liquid flow between the bottom of the ABS controller and the top of the pump ..... basically those studs that you see for controlling each line.
Reason is I have two good holes .... would that be enough to hold in place ... or need all four to help hold properly .... just unsure how that abs stud mechanism works exactly
Take the pump block off and bring it in to a machine shop, let them do it. They have the experience and the tools to get it out and re due the hole threads. When you get it back reinstall and bled the brake system.
Edited by IBMobile
:duh: It don't look like you were using any tapping oil of any sort. Also it looks like you attempted to tap in a single pass. Usually tapping is a in and out process cutting a little and cleaning your tap of cuttings to prevent binding. Smaller taps tend to break rather easy.
Correct on most of this .... didn't know although tried to be careful
I can get a used pump for $100 .... think this is cheaper option ...... i had thought the same too ....
