engine dies after hard acceleration, hard start/no start after
Having an issue and just starting to look for the cause. Have a 1999 24v with a 5 speed transmission that will shut down after you let off the accelerator when you accelerate hard. After it dies you have to crank the engine excessively to get it to restart. At times it won't restart unless you pull/coast start it or bleed the injector lines.
  • Replies 29
  • Views 16.2k
  • It's pretty common. There's at least a few threads about it on this site alone. Happened to me once. One theory, that I particularly like, is that while standing on the throttle, maybe timing is a lit
  • dieselautopower
    dieselautopower
    Ease out of the throttle and should fix it.  Bigger high pressure lines and drilled out fuel connector tubes seem to make it worse.
That's different than when you let off for sure. The letting off an dying is common. Research my friends.
I've done that.  Shocked me the first time and I thought I fried my pump.  I stood on it with an edge comp-smarty stack and let off quickly at about 35mph.
Crack an injector, spin it, restart it, and learn to roll off the throttle a bit or learn to blip when you stop pulling.  Basically you can make the VP44 lose prime by going from full flow and high boost to idle too fast.  In a lot of pulling videos you will see guys stop pulling then see their trucks snort once or twice before idling smooth. They are stabbing the throttle.
I pulled the truck twice about 40 minutes before my dad went to pull. I had zero issues other than picking the wrong gear. He hooked to the sled and the truck died before it moved 10 feet, didn't even have the clutch fully engaged.
I did find another issue tonight, the holder for the crank sensor was stored open and allowing the sensor to move in and out about 1/88 of an inch. Replaced the sensor hold down, had a bolt break off in the starter so didn't get it started but going to pull again Friday night so we will see what happens.
  • 2 years later...
Anyone ever figure this out? I’m having the same exact problem now
It's pretty common. There's at least a few threads about it on this site alone. Happened to me once. One theory, that I particularly like, is that while standing on the throttle, maybe timing is a little too advanced, pressures in the cylinder are very high. While cylinder pressures are still high, and you let off the throttle very abruptly, the pressure in the cylinder may overcome the injector, and backfeed air into the fuel line.
I'm not saying that this is for sure the problem, as I think there are multiple schools of thought for this. I'm not 100% sold on it, but it has some merit. All I know is I bled my fuel lines and it never happened again. I have also since raised my injector pop pressure, maybe that's coincidental.
Try not to let off the go-pedal too fast, and carry a 3/4 wrench with you. I've learned not to let off too fast in most cases anyway, because I don't like to bark my turbo.
nature of the beast,  if you let off of the throttle to fast you run the risk of stalling.  Crack the lines crank and keep going.
30 PSI of boost and just compression will produce 1,100 PSI of cylinder pressure without fuel injected. Add heavy shot of fuel and advanced timing I'm pretty sure at some point the injectors could be overwhelmed by cylinder pressures more so with high boost runs. This why you see drivers throttle tap couple of time after a drop of throttle to keep fuel flowing till cylinder pressures fall.
reading through the thread, this is the thought i had as well, with enough PSI the injectors work both ways lol
