- Replies 36
- Views 6.7k
ronman 13 posts
Mopar1973Man 9 posts
dripley 4 posts
TFaoro 2 posts
19psi while running yesterday, around 10 cranking, plenty of fuel coming out when I loosen the return banjo. Nothing more than a slight trickle out the back/at the injectors while cranking. Tries to start on ether (grid delete, sprayed through the boost bolt) but since there's no fuel it's unsustainable.
First VP went out at ~130K while towing. I replaced it with one from a truck at a friend's shop that he had owned since new but had a cracked 53 block, and I've been running on it ever since.
Last night, after driving all day, I went to Daytona to bring an engine crane to a racer friend who's running the SCCA Nationals, and shut it off so we could hang out for a bit and catch up. I pretty quickly determined there was no high pressure fuel and we towed it back to my place, 45 minutes away. Now I need a pump.
What do you all like?
Notable points:
FASS150 was installed with this injector pump. The truck it came off of had a stock pump, but for the past 115K it's been fed plenty of fuel with 8oz of 2-stroke oil added at each fillup.
There are no codes other than my normal P0122 from my flaky Timbo APPS.
Cold starts have been 1-2 sec key turn and it jumps to life. Hot starts have, for the last probably 18 months, been difficult. Usually I had to cycle the fuel pump 3-4 times before even thinking about cranking, and even then probably half the time it still needed a small shot of ether to get going. The last couple weeks, after starting, it would "hiccup" for just a fraction of a second after it started.
Edited by ronman
