The time has come to produce the Mopar1973Man High Idle & MPG fooler switches again.
Well Gang,
The Board of Directors on the Mopar1973Man.com has decided that we need to produce some new High Idle Switches for the 2nd gen 24V Cummins.  We have spent a considerable amount of time designing a Brand New High Idle / MPG fooler Switch.
We have learned from the last switch design and have made significant improvements.  The New High Idle / MPG Fooler switch will be the same price as before, but it will be more robust and modular to allow for easier install.
We have decided to only offer a "Install Anywhere  Kit" rather than a gauge mount or Cubby Mount.  You will nly have to drill one 1/4" hole to allow for the fitment of the switch.
Some teaser pictures.
We are making 50 switches to start then another run of 50 after that.  You can order them from The Mopar1973Man.com Store I expect to have them ready to ship within a 6 week time.
  • Replies 438
  • Views 83.1k
  • Got my switch installed. I'm about to jump over to CF to post a quick install write up, I just wanted to share that the switch does in fact fit in the overhead console. As already discussed, the wire
    All high idle sales will be here on the site for here on out. We will be the producers, vendors and the support team rolled into one...
  • I finally installed my high idle switch today.  I put in in the overhead console.  The cable that comes with the switch is just a little too short.  I ordered a 12" extension from Amazon and I was abl
9 hours ago, joecool911 said:
What about a potato in the tail pipe?
8 hours ago, Me78569 said:
i'd use a yam
Thanks Nick. That would be insulting to use a "Idaho Potato" for a exhaust brake. :lmao:
It is very difficult to beat the exhaust braking capability of an Idaho potato. Their characteristics make the best for use in potato guns also. Just hard to beat. Check it out.
Some things are tough to resist. :moon: Check out the pm I sent you. It could be worse.
On February 3, 2016 at 11:04 AM, Me78569 said:
I dunno if I have asked this before or not, but do you have anything to read live data from the ECM?  ( quadziila, edge attitude, scan gauge, etc)
No, I don't. I have a comp box
Is this next go around of switches the one with LEDs?!?
I need a new switch for the new rig! :wink:
All I needed to hear was 'shiney lights' and I was sold! :lmao:
Great.
Figures when you insure the package they never break anything.
Alright,
We got word that we should be seeing the harness's for the Mopar1973Man High Idle Switches by the end of next week.
On 2/10/2016 at 7:14 PM, Mopar1973Man said:
I called the cable manufacture I had him break it into 2 batch so we can get them sooner.
whats the update on the switches Mike
Still waiting on the harnesses.
Should be any day that we get them.
Just in time for tax returns.
Sweet thanks for responding keep this post updated ill keep checking the store i hate having to park my truck out side to make it enable high idle. I was going to build one but i don't feel like going through the trouble.
I have read though most of this thread but not all.. Is this the only switch out there that has MPG fooler? Is there a MPG only switch? I had 6 cylinder enabled by a smarty and don't think I really need 3 cylinder. Am I correct that because I have a grid delete that I can just leave this in MPG mode all the time? If on a cold enough day... will the programmed 6 cylinder mode kick in while in MPG mode on this switch?
