moisture from lower vent
- Replies 26
- Views 6.1k
John T 10 posts
Mopar1973Man 7 posts
gassernomore 2 posts
Me78569 2 posts
Just rethinking a second. The drain is most likely plugged up. The Defrost setting will run the A/C compressor. It could be condensation. Check the drain for a plug first.
Not hard at all to do just time consuming. I've got heater core job coming Sunday.
For a couple months now I noticed moisture dripping from the floor vent on the passenger side of the tranny hump. right next to the " SRS" cover (I hope that makes sense)
The moisture is mixed with what I THINK is green paint from when I painted my truck about 4 years ago and got overspray into the exterior vent at the bottom of my windshield.
I know that sounds strange because it seems whatever paint was in there would have dried long ago. So I am open to suggestions for other explanations for the green stuff.
While I first thought the moisture was water, now Im not so sure because it feels somewhat oily. any thoughts?
Ill try to post a pic to help explain.
this is a '96 2500 totally stock
