- Replies 11
 - Views 2.4k
								The_Hammer 4 posts
								dripley 2 posts
								notlimah 2 posts
								Me78569 1 post
Popular Days
I was surprised how much the end links do affect sway. I finally got longer end links on the front after doing the level kit. Before I was running the shorter factory ones and the truck was like a roc
I dont know that it is the sole cause but it is the likely cause. They are not expensive and worth putting on. You can just by the bushing if the links are still in good shape.
@CSM I'm running 35x12.50's so I need the leveling kit. @notlimah It was in stock when I ordered, took 4 days to get it. DO NOT buy anything from DOR that isn't in stock unless you wan
My truck has been feeling unstable lately when hitting bumps. It seems to sway left and right easily in a quick jerking motion. My end links are definitely worm and was wondering if this could be the sole cause of the issue?
Truck has new Bilstien 5100's, DOR track bar with no play, ball joints don't have play, unit bearings don't have play, and all steering linkages are new and have no play.
