- Replies 31
- Views 9.5k
dripley 7 posts
Hawkez 7 posts
Me78569 5 posts
Mopar1973Man 4 posts
The 1999 SO trucks came with the optional 5600, and the tranny came with the smaller 1 1/4" input shaft like the 4500. To be sure if you have the SO or the HO, you can confirm with the VIN. If the 8
I was not trying to muddy the water though it seems I accomplished that. With the cost of the pumps and cores, just did not want to see someone get stuck.
look at the tag on your motor, is it a 245 ho or a 235 so? I know some early 6 speed trucks were SO's still. re
I thought I had it all figured out, I called DAP today and they told me the opposite of what I thought I knew. Is the only way to find the correct pump that I need, to pull the old one?
