I'm not really a fan of seeing a big tip on exhaust or seeing  the exhaust pipe at all. So.. a few weeks ago I cut the last few feet of the exhaust for an axle dump. What I didn't realize was how much louder it would be and how much drone and vibration would come as a result. :doh: I had a hanger/support installed but its a couple/few feet up from the end. So over the axle.. there's no support. I don't mind it being a little louder but the drone and vibration is driving me nutz <--- no pun intended. Do you think another hanger near the end would help alleviate this.. or no?
  • Replies 23
  • Views 13.4k
  • Wild and Free
    Wild and Free
    At that point you will be in need of a long resonator or a very good muffler or both to eliminate that noise. On my 2010 Hemi a couple years ago I had a guy back into my right rear and kink the e
  • Patience my friend... cut slices down the outer pipe, as many as you need. Then use a small chisel to bend the tabs out. Then twist the pipe until it comes loose. If you need to squirt WD40 in the joi
  • CTcummins24V
    CTcummins24V
    Not a driving, yet.
On my 2010 Hemi a couple years ago I had a guy back into my right rear and kink the exhaust pipe shut and the system on it has a resonator right in the end of the exhaust with a short tail pipe exiting the side, I thought I would take off the factory resonator and see how it would sound and perform and it basically ended at the axle under the box as well. Was the longest month I had, it sounded like a straight piped derby car dumping it underneath like that even with the mufflers, I was totally amazed at how much quieter it is with a simple resonator at the end of the system. I ordered a factory resonator and tail pipe assembly and have not been happier.
2 minutes ago, Mopar1973Man said:
For the money it would be just smart to just do a exhaust system for your truck.
What do you mean? Just have someone add the back section back on?
No replace everything from the turbo to the rear bumper. I just finished an exhaust kit on a 1995 Dodge replaced every bit of the exhaust system. So much nicer going from straight pipe 5" dumped forward of the rear axle to 4" fully mufflered, full exhaust all the way to the tail. Turn out excellent. The owner extremely pleased. The 5" at 60-65 MPH the drone was so bad two people couldn't talk in the cab unless you slowed down to 50 MPH. Full exhaust system is right around $350 bucks and all new then.
I don't really think I need a whole new exhaust... do I?!?! It's in good shape... just missing the last 3 feet.. lol
picture... I'm not sure if this is a muffler or resonator..
Wade convince you to do that?? Personally I've never liked them. Loud, gets smoke all over the back of the truck, etc.
Did you have a stock system?
1 minute ago, Mopar1973Man said:
Call some of the vendors you might be able to order just the tail tip too...
I've never had good luck with that. hopefully he will.
When I bought a new tip, my tailpipe was too short. I just welded in a new chunk and painted it with high temp paint. No issues yet.
no lol.. wade didn't say a thing. It's just my preference.
I was hoping another strategic hang would help.. but guess not
I may have someone do some custom bends so little shows..
It might help. You can always try! Just remember, the more hidden it is the more smoke will stick to the truck.
Then you should be able to order just the tail section from MBRP...
Maybe but itll be x amount of inches short because I couldn't get it to separate.. so I cut it
Patience my friend... cut slices down the outer pipe, as many as you need. Then use a small chisel to bend the tabs out. Then twist the pipe until it comes loose. If you need to squirt WD40 in the joint. Works every time
Then just weld up the slices. I'd find a welder if I were you to put it back together.
Hmm.. should have thought about this back then :-( oh well.. too late. Piece was trashed the next day. Thanks for the replies!
This and another thread I've been following on CF really has me debating on putting a 4in tbe on this truck. It's such a double edged sword! It sounds amazing, but any time someone else is with you, bye bye conversations haha
Put a cutout on that you can control from inside the cab and have the best of both worlds
It wasn't a problem before I cut the end off. Can still hold a conversation.. just have to speak a little louder :-)
I have been running a 4" since 2006 and I hear more noise from under the hood than the exhaust. I do still hear it and want to put a FTE resonator on it one day just to see what difference it makes.
We had a thread earlier about resonators, they work. I switched from a 4" to a 5", both systems had mufflers. But the 5" was droned so bad, so I added an FTE resonator and it's back to normal loud cummins.
Your picture is the muffler. MBRP has a straight through muffler, so it's loud! Either way, you should secure the rear of the exhaust so it's not bouncing around and causing excess stress on the closest rubber insulators.
So you're running a 5in tbe with a muffler and resonator? Do you have a video?
