- Replies 22
- Views 6.8k
dripley 6 posts
Buzzinhalfdozen 5 posts
JAG1 3 posts
CSM 2 posts
Popular Days
The first and second set are not the Alcoas. Stay with 95-97 8 lug ford rims. that is the only years for forged wheels with the good metallurgy. The process for a forged wheel is so expensive Ford qui
The first listing for superduty wheels won't fit, that generation has a different lug spacing. The only Ford wheels that fit are pre 97 I believe. The second set should fit. The 8x6.5" he's refe
Went in to the tire store today with a slow leaking tire. Turns out to be a cracked rim. I bought a used set of oe rims a while back so I have some spares, but with 3 rims with cracks I dont think what I have is going to last much longer. So I have done alot of looking this evening and while there are a lot of wheels out there I find very few that have the same off set and backspace as the OE. From my research and doing some measuring of the OE rims it would appear I need a 43mm off set and 6.2" back space. Not sure why you need the 2 measurements. It would seem to me the they are 2 different ways to measure the same thing. Almost everything I saw had a 0mm off set. Not sure I want the wheels sticking out another 1 3/4" from where they are now.
I guess what I need to know is if I am reading these measurements right? I did not have this trouble with my trailer wheels, they were marked and I had plenty of choices. What are some of you all running?
