Engine Stutter/cough on acceleration...is vp44 bad?
Hello all,
I have a 2001 24valve Dodge ram 2500 automatic.  Wonder if my vp44 is bad.  Today when driving,  on acceleration I got a really bad stutter/cough in the engine.  I double checked the voltage on the timbo apps and it is in spec and no dead spots. On the raptor pure flow the fuel pressure is 15psi at idle and around 12psi when accelerating. I have changed the alternator, it's in spec, I even disconnected fuse and harness to isolate if it could be that and it didn't go away. On low pressure side of vp44 primed to make sure no air on that side.  No error codes and at my wits end what to do next.  attaching a video if that helps.
any thoughts?
IMG_7611.m4v
  • Replies 72
  • Views 29.7k
  • Dieselfuture
    Dieselfuture
    double check codes with a good reader, how old injectors, 12psi is a bit low but don't think it would do that, noticed your oil pressure is low could be a bad oil sending unit that is cutting 5 volts
  • I am with you on checking a few more things.  Having the injectors pop tested sounds like a good plan.  I have an electronic fuel pressure gauge on the lift pump.  I hooked up a mechanical gauge and d
  • Ok.  Face in hands shaking head...embarrassment! haha   *****Problem Solved*****   Loose positive cable (can't believe I over looked that one)  and Loose connector into vp44.  Left my truck at Rincon
16 hours ago, dripley said:
Dont know how you could have 160.8 volts on a 12v system.
Probably has it on the wrong setting on multimeter or it's too cheap to give a correct reading
He is also getting some other weird readings on othersensors too. I looked Autel and they offer a lot of different scanners and they aint cheap. Hope that means they are of good quality.
Oh yes. I spare no expense on my truck and keeping it running. Believe me. Lol
But any ideas as to what could cause that stutter?
I dont know. What I do know is that your apps and boost  should reading near 5v. Not the numbers your seeing and it is very odd that you have no codes. Bit of mystery. Maybe something is wrong with the scanner. Just hard to say. Somebody body correct me if I am wrong on the 5v sensor voltage but the apps is in another world and the boost is in the cellar. All the sensors are on a 5v circuit.
Is there a way to “manually” probe wires to check the true voltage going to those systems (instead of what the computer is telling me? If so, which wire(s) do I probe?
Here’s the codes I discovered.
The 121 might explain the weird APPS voltage reading.
The 216 most likely will explain your stutter. The vp is gone.
Just replaced mine back on Thanksgiving with the same code.
Edited by dripley
Lovely... So I need a new VP pump then?
I was also reading that if I replace that that I also have to replace my lift pump as well...?
The 216 is a mechanical failure in the VP. Usually it is a lift pump failure that takes the VP with it from what l have heard. If you still have the stock lift pump on the block, I would replace it no matter what. They are not great pumps.
After looking online and being floored but the amount of money it costs to replace the pump, I came across the DDRP Relocation pump (says it’s designed to go closer to the fuel tank rather than in the engine bay and acts more as a pusher pump) for much cheaper than the OEM part. Could that be a viable (and cheaper) solution to my problem?
The DDRP will work for your lift pump but that won't help with the VP pump issue.  You will still need to replace them both.  Did you verify that you still have the stock pump on the engine?
@Zekeworst, even though the 0216 code is a timing failure code within the VP44 injection pump, I wouldn't replace it just yet.  I would inspect / clean all battery connections and ground locations.  I would also investigate the APPS voltage to ensure that you are within the correct voltage range.  Then, I would clear the codes, drive the truck and see what happens.
- John
Edited by Tractorman
There are 2 pumps. One the VP and 2 the lft pump. The VP is the pricey one.you need to checkout DAP or Vulcan performance  for a VP. They are still about $1000  but still much cheaper than most any one. The DDRP is a lift pump. Your main problem is the VP44 which is your injection pump. That being said your lift pump could easily be the reason your VP died. Do you have a fuel pressure gauge?
Here’s what my pump looks like. It’s got torque paint on it so I’m assuming it’s stock. There’s also the numbers 1022204 inscribed on the plate cover.
3 minutes ago, Tractorman said:
Even though 0216 code is a timing failure code within the VP44 injection pump, I wouldn't replace it just yet.  I would inspect / clean all battery connections and ground locations.  I would also investigate the APPS voltage to ensure that you are within the correct voltage range.  Then, I would clear the codes and drive the truck and see what happens.
- John
Agreed.  Before dropping $1200 for a new VP better to check and make sure it actually is bad...  Good point John.
I do not have a fuel pressure gauge. So the pump isn’t dead yet? I feel like if I were to replace the lifter pump that it would save the VP pump long enough to squeeze a little bit more life out of her.
- John
Where are all the ground terminals? Easy to get to I hope... I know where a few are but finding and going through the rest of them may take awhile.
That is your VP.  You need to follow that fuel line back along the engine, it will go to a filter canister then to a small electric fuel pump (if its still stock).  If it still has that small electric lift pump then its still stock.  If not then either there was an upgrade put in the tank or on the frame somewhere.
Check out his apps voltage above. It is out of range. 160.8v
It is possible a new lift might help and if you have the stock pump or in tank pump you need to replace it. Whether that will solve the problem is a gamble.
Edited by dripley
Also: I apologize for all of you who may think I’m asking “stupid” questions. I’ve never owned a diesel before and I’m just trying to make sure I can (hopefully) pass this truck on to my future child(ren).
Yup. It’s stock. I see a mopar sticker on it.
So... From what I’m gathering, I can either:
A. Replace the lift and in tank pump and hope it fixes the problem
B. Replace the VP pump (which will most likely fix the problem
C. Replace all of those components and KNOW it will fix the problem. Damn owning a diesel is an expensive hobby... ?
I also just noticed that there’s a slight crimp on the inlet side of that lift pump. That could be why it’s doing all of this. I’ll see if I can uncrimp it.
Edited by Zekeworst
If you dont have a FP gauge you could get test maybe from an auto parts store and check it.
