- Replies 37
- Views 7.9k
leathermaneod 10 posts
notlimah 9 posts
Dieselfuture 6 posts
Mopar1973Man 5 posts
Popular Days
notlimah, I think I may be able to provide an answer to both of your issues as I have experienced both, the first for sure anyway. First, your gauge not registering pressure until after startup is an
As far as the overflow valve opening, I believe you are correct that it should stay open at all times when pressure is above 14 psi. However, I think FASS was saying that it might be hanging up due to
Ok so since I'm on my second ISSPRO gauge in this truck, I've been paying extra attention to it and the FASS. Well I've noticed a couple things and just wanted to clear the air. I don't think anything a wrong but just wanted to get some extra input before I moved on to worrying about the next thing.
Currently have less then 1/4 tank so keep that in mind...
If/when I bump the starter, the FASS will run/prime but I don't see any fuel pressure build on my gauge. Once I finally start it takes 5+ seconds before it shows any readings which end up between 16-18 at any given point.
- Anything to worry about here?
While driving I noticed recently that the needle would bounce around a couple psi with no relation to throttle input.
-Could this be because of low fuel?
Finally, my gauge is setup with just a tee into the fuel line, to a needle valve, then gauge. The needle valve is cracked literally as little as possible to get a reading on the gauge. The way it's setup now I can't see a cranking pressure (if it takes that long to start) since it takes a bit to build pressure.
-Should I open it a little more to get a quicker response from the gauge?
