- Replies 29
- Views 5.8k
Wild and Free 14 posts
01cummins4ever 4 posts
dripley 3 posts
TFaoro 3 posts
Well finally got around to getting started on the engine project on the hunk. Pushed it into the shop and got the engine on the ground in about 6 hours time, had the loader and front driveline off pri
Yep, it must be tractor splitting season. It it took me about 4 hours to get mine split and transmission sitting on bench, I think Kubota dealer gets a little over 6 hours for a complete
Boooooo. I'm looking for a smaller tractor with a loader. The 4020 we have is okay, but is a little bigger than we need. The 1466 turbo we have is just way too big.
Found a deal too good to pass up on Monday. Found a 34HP 4 cyl diesel 1987 L2850 Kubota 4x4 tractor 1700 hours with loader and fairly new tires, implements it came with were a 6 foot JD finish mower and a 6 foot rotary brush mower and a box scraper and cultivator, package deal for $4500. Can sell off the mowers and other stuff and recover close to 2K there alone.Tractor and implements all in super shape but the project portion is that the engine has a bad knock. I did not start it to not cause any further damage but did crank it over to confirm it does have one.
So I plan to drop the oil pan shortly to inspect and see what broke and what direction I want to go.
Win win for me no matter what, tractor with loader is worth $8-10k and worst case I wind up putting a reman engine in I have found them for the $3k range or a complete rebuild kit for $750 plus whatever extra broke like rod or damaged crank shaft and machine work and overhaul it myself all depends on what I find damaged once oil pan is down, if all looks good I will overhaul it myself.
