- Replies 26
- Views 38.7k
AH64ID 8 posts
BIG-BLACK-DODGE 5 posts
Mopar1973Man 4 posts
KATOOM 2 posts
And I wouldn't have thought that Airdog and FASS would have used inferior filters on the lift pumps but they did so for a number of years, all while claiming improved filtration. When I s
If anyone is interested, below is the spec sheet for the OEM 5600 fluid. And in regards to High Gear Transmissions stance on Mobil, I have to wonder if they'd say the same about Valvoline
That is incorrect. I read up on it for days and the closest oil was a texico brand. Either way it's change a few times in it's life. To me it's not worth experimenting with different oils in this case
So I'm just double checking since I've read different things. What fluid do I put in my Nv5600 that calls for the Texaco stf 1864 that is not made any more?
Edited by CSM
