Dirty battery cable...Trans shift weird.
- Replies 9
- Views 2.3k
Mopar1973Man 2 posts
JAG1 2 posts
notlimah 2 posts
dripley 1 post
Popular Days
Yea loose connections in regards to batteries can cause all sorts of weird things. Just last week a guy I work with has an old ford gasser and he said it was driving and shifting really we
I soldered my ends on. At least the ones that went bad. Just kind of doing them as they wear. Harbor Freight has the shrink wrap with the adhesive.
Personally, I like soldering on the terminals being the solder will creep inside the vinyl jacket and also seal the copper from future corrosion issues. The soldering has welded the copper to the term
I know from previous experience that a corroded battery cable can effect transmission shifting. But why? Does the bad connection create AC noise or totally different issue?
