TIRES
My tires need replaced before winter makes its head. What's the popular suggestion for tires these days?
I'm half pave half off road. It snows a boat load in the winter. I'd like something with a high load rating, but also aggressive enough to keep my traction and give me longevity. While i realize I'm asking for the perfect tire, there has to be something close!
I'm thinking about going with oem size tires also. But I've also wondered about different wheels and sizes.
So what's everyone say...
Edited by hex0rz
  • Replies 106
  • Views 25.5k
    LOL... My version I found...
  • Killer223
    Killer223
    best tire's i've had in snow so far was cooper AT3's next would be the BFG AT Ko2's then the Michelin LTX A/T 2's as for road noise and longevity i'd have to vote for the LTX's  they are awesome
  • Wild and Free
    Wild and Free
    Same goes for a stock trailer full of critters that weigh 1200-2k lbs and jostling around.
Tires I bought from Les Schwab look very similar in tread, tread deth, even pattern and do very well in snow and ice.
Those Hankook Dyna pro at's are awesome. They are really popular here, That is whats on my 05 right now and they are a great all around tire and are wearing awesome, Thinking I will have around 60K on them by the time I take them off.
I just scored a set of aftermarket aluminum wheels with half tread Cooper stt's on them for 400 bucks. will run them out this winter and see if I like the wheels or not they have a wider than stock off set so not sure if I will like them or not but couldn't go wrong for 400 bucks. A no loose deal all around either way.
Cooper STT I like the traction value for offroad but I didn't like the idea of then being about another 10-15 pounds heavier than normal 265/75 R16. I saw a mild loss in MPG with the Cooper STT's I sold mine back to the same tire shop I bought them from with about 30-40% tread left.
Good to hear about the Hankook DynaPro's... :thumbup2:
The Coopers STT's do have some noise to them. If you air them up properly they actually do have good traction and performance. Your Meme above does hit the nail for majority of puppies out there buying tires and wheels for their truck today.
The Dyna pro's look very comparable to the ATP's I have been running. I will give them a serious look as I am not to far away from a set of tires myself. It is always nice to have something else that is not an unknown to bargain with.
I had high hopes for the Black Lion's for wear but it didn't come to be. So this go around I told the tire tech I was looking for something a bit better than bargain basement stuff but something with quality and going to last awhile. So I know Hankook has be around awhile and should have good performance. The DynaPro's are suppose to designed around the high torque of diesel trucks so the compound of rubber should be a bit harder.
On 7/17/2016 at 6:55 PM, Mopar1973Man said:
16 x 7.0 Aluminum wheels. Stock is 16 x 7.5 wheel.
I went out and checked my OE's and they are 16 X 8. I have 3 on bare and on the ground. Wider wheel with the 265 option vs the 245's?
That is interesting to know.
Well I can't verify the measurement because my rims crack and the next day were headed to the scrap yard. I was stating I guess incorrect second hand information then. :doh: I had 265's from the factory.
Has anyone seen the Hercules Trail Digger MT? That is a mean looking tire if you like the aggressive look.  I have a friend in AZ that runs the 35x12.50x20 on a lifted Avalanche and we tried really hard to get stuck but those things just kept digging. Never had to put it in 4wd.  I was looking at the Hercules Terra Trac AT II. Those tires have a 60k mileage warranty on them and shouldn't howl too loud.
All we run at the coal mine are Toyo open country MT tires, if one can spin them they clean out and will move you, only time one gets stuck is if one gets high centered. We have clay mud gumbo about 10 thousand times more slick than glare ice and about that much stickier than road tar lol.
Then you should be rather happy with Cooper STT's they are nearly the same tread pattern just slight differences to the Toyo M/T's
Here are pics of my new $400 "Digs" lol. also one of my new Treadwright Wardens on top of the coopers.
Edited by Wild and Free
The warden is on top of the coopers in the bottom pic?
Yes. Warden is a lot nicer tire all around in my mind.
I think I'm going to try a set of Nitto Terra Grappler G2 tires in size 285/70/17. My brother has these and is Very happy with them! With how much power he has it's hard to find a tire that doesn't spin and these have gotten the job done for him.
I'm going a bit bigger to drop RPMs from the transmission change. I'll be happy if rpms drop and mileage remains about the same.
54 minutes ago, joecool911 said:
Not studable?
I've never run studs. Rare to see me use 4WD in the winter. Even more rare to see me put chains on.
Notice how flat that road is. Not pulling a trailer either
Edited by Royal Squire
