47re tranny problems
- Replies 80
- Views 21k
wagntagn 28 posts
Mopar1973Man 13 posts
notlimah 10 posts
Dynamic 6 posts
Could be a valve body issue, but it could be a problem with the intermediate band or servo. "Built" automatics should not shuttle shift anymore than a stock one should. I build 200+ trans
Yes... This is correct. One of the primary benefits of a cast aluminum pan, in addition to carrying extra fluid.
That's a lot of AC voltage, but I'm not 100% sure that's your problem if you're having shuttle shifts. Again, what governor pressure solenoid was used in the build? It looks like a pretty generic "box
Last year I got my tranny completely rebuilt,our local tranny specialist put everything heavy duty and it never performed too good it seemed like the shifting was sluggish from 1st to 2nd and now 9000K later the tranny let go again he pulled it apart and everything was wore out he replaced everything under warranty and he mentioned that the problem was the alternator, as anybody experience something similar?
