- Replies 18
- Views 2.8k
Popular Days
Just to clarify. The truck ran out of fuel? You have recently changed the filter? After you prime the fuel system, you can hear the lift pump run, but it is running louder. After it primes it will
Are you cracking a couple injectors loose to reprime?
A few things could have happened..... Your fuel pump could have quit and you're not getting the correct fuel pressure or volume in order to get the truck running. You could hav
I NEED HELP TRUCK RUNS OUT OF FUEL AND I SHUT KEY OFF AND LET LIFT PUMP FILL FILTER AND IT WILL RUN FINE FOR A MIN OR SO THEN DO THE SAME THING REPLACED FILTER AND HAS A AIR DOG RAFTER LIFT PUMP THAT IS NOT AS LOUD AS I REMEMBER IT BEING. I'M STUCK AT WALMART PARKING LOT TILL I FIGURE OUT DON'T HAVE MUCH MONEY TO TRY THINGS LIKE NEW LIFT PUMP IF THAT'S NOT IT I PUT THAT ONE ON A LITTLE OVER A YEAR AGO. ANY HELP IS GREATLY APPRECIATED
THANKS
