- Replies 11
- Views 3.2k
CSM 3 posts
notlimah 3 posts
Mopar1973Man 1 post
BBHD 1 post
Popular Days
The only thing you need to do is open up the driver side door and pull the IOD fuse out of the socket. That's it. This disconnects the battery from the truck. Don't need to jack up the axl
If it ain't leakin it shouldn't be flying!! T-56 life!
I garage mine over winter....I have my reasons. But I will drive it as much as possible if the roads are clear during the months it sits (our last winter wasn't bad snow-wise). No issues with leaks
I plan on storing my Cummins from November to April other then making sure coolant is up to snuff and antigel is in full and full tank and float charger what else should I do air tires to max psi to prevent flat spotting ? Need tips here guys
Also going to be inside on gravel floor so dryer sheets every where lol
