Injectors
Need a new set more than likely. Going to Getty mine bench tested. But need good information beforehand just in case.
Shed your knowledge on injectors on me. Who to go with and why.
I've heard a bit but need set straight on some things. My DAP set is less than 40k on me and at least one of them is bad. I don't like that idea...
  • Replies 145
  • Views 30k
    There was a TSB for early model truck for change out of cross over tubes because it is easy to crush or distort the crossover tubes.   Another thought is that it's possible the pooled fuel i
  • Normally teflon would bother me. If you just put the tape on the threads for the nuts to screw on then it is outside of the fuel system. The threads on those nuts do not seal anything. They allow the
    Bad injector o-ring will leak fuel into the oil just as @dripley said. Bad crossover o-ring will leak fuel out on the intake manifold. It will not leak fuel into the oil. Bad copper washer w
Sigh....
I'm hazing at idle and am sure it's been this way since the injector install. Just gave it time to see if it would change any at all.
I'm sure my tires have something to do with it too, but my fuel mileage is not so good and the egts still run hot. If i cruise at 65mph down the highway I'm at 800. Before, i would be around 700 at best.
Sitting here, i have an 1/8th of a tank left and am at 359 miles!!! Granted i have done some snow plowing and 4wd too.  But still terrible... i think i might buy new injectors. I'm so fed up with this!
I am truly sorry to hear your issues, right now my stock injectors are still in with 316k on them.  My fuel millage is down a little bit but the truck still runs great.  I'm leary to open a can of worms but know I need injectors.
DAP was on my list but I'm starting to reconsider.  I have a local shop that I will contact, they sell industrial injection, new Bosch rv 275 and they also build their own, they have their own equipment, I'm kind of thinking this is the way to go.  Still not sure on injectors brand or size.
I hope you can find success or a high quality local shop that will sell you something or rebuild them then stand behind their product.
I drove 60 miles round trip in the snow/ ice, 5 accidents, two rollovers, to go to Vulcan and get my new injectors yesterday. I told Eric to get me rebuilts, pop tested and flow matched. For some reason, and I did not ask why he took it upon himself to order brand new ones from Bosch. The new ones were not a whole lot more money from what he quoted..... I was surprised. to say the least.
I do know..... the way Eric is..... he's always right and done me good over the years. For such a little shop out in the woods, they are always big on doing good.
BTW, they are for my first gen. Originals had 450 k on them which is going dangerously too long. May have destroyed the engine. We'll have to wait see.
@JAG1 my local shop wI'll rebuild Chevy and Ford but recommends only new for Dodge... :think:
Then I get told over 300k no new tubes no warranty ok I say I'll take tubes and rv275s.  He then asks "are you installing these yourself" and I respond "yes" he responds well that will void warranty. :doh:
So I'm now calling around to see about other options.
Does that seam like poor service or is that pretty "a" typical?  did I mention it would cost about 930 dollars installed?
Edited by WiscoRedkneck
You would have been even more upset when having to deal with industrial infection. Any injector builder worth their salt will warranty their product. Reason I use Infinite performance. Also highly recommend HSI.
I have done a little searching on injectors.and nowhere have I seen self install voiding a warranty nor only new for a Dodge Cummins. Maybe I have led a sheltered life. Have not seen it mentioned here before from anyone. On top of that even "My Dumb ***" can install injectors in a couple hours in my dirveway. $930 for that package, even including tubes, is whacky. You have to pull the tubes to do the injectors.
I planned on installing them myself, I'm probably going to get rv275s from Vulcan install them myself and call it a day....
While I put my 275's after the Banks system I installed, they were a nice little bump in power and I saw about 1 mpg increase in mileage. I am hoping with 50;s or so I might see the same. Only time will tell. My 275;s came from DAP with no issues. Not knocking Vulcan, just thought it ought to be said.
Edited by dripley
Vulcan will warranty them. I just got mine running. It's got a little lope but there is a high pressure line that is dripping behind the VE pump. Tomorrow I will get a special tool that will work in there and retighten all the lines.
I'm so dog gone happy its not the injection pump.... Michael Nelson coached me over the phone on getting it primed. Only about about 15 phone calls...... not really but a lot of calls. It can be tough to get it primed.
I
I do not want to put words in their mouth but I would take "new" to mean not rebuilding what he had. The cost for a replacement set of injectors is not out of sight, generally.
This settles it. I'm going to buy a set of the rv275 from VP. don't see many Others offering genuine Bosch bodies when they say rv275 with their injectors. That's not an rv275, imo. It's just a 40hp injector, lol.
@hex0rz I agree 100% I found alot of rv275 rebuilds and then aftermarket branded rv275s.
Rv275s is what I will probably run but a friend told me to check out farmboydiesel, after talking with them on the phone those guys seam like a good group.  Though I would like to hear opinions from you guys if you have any...  Their rebuilds are very competitive pricing wise so I am mildly intrigued by that because if I can get two sets for the price of the most expensive new set then why not and have a second set on hand, hopefully they don't last just one year or so....
7 hours ago, Mopar1973Man said:
The other one you could try is Vulcan Performance. Eric been really good about taking care of my needs for injectors too.
If I go with rv275s that is who I would buy from.  After reading around a bit I'm getting the drift that their customer service is always on or above par.
I dropped some green on a set of rv275s from Vulcan 2 days ago. Hope to see it in the mail soon.
Should i be concerned about the injectors being flow matched pop tested with them?
Does he even do that with them or just take 6 off the shelf and pack them up?
The other thing that just occurred to me is, could my cetane numbers for my fuel be part of the problem?
Eric doesn't have the equipment to do that. He knows the people he orders from and
 they are all top notch since he himself knows what to look for.
I've been to his place 4 times... spent most of a day a couple times. He is honest as they come
As far as the rv's, I believe they come from Bosch and sold as is. But i would think they have to pass Bosch standards at the least. FWIW anyway,
Vulcan has always been good to me.  I always look there first to see of they have what I need.
I liked my 275s.  For a stock turbo they are great.
