Quadzilla V2 Custom Tunes
Quote
Power Levels:
Timing
Fuel Load Timing:
Low PSI Timing Reduct:
Timing Reduct Scaling:
Light Throttle Timing Adv:
Timing vs rpm
1500:
2000:
2500:
3000:
Timing Max:
Wiretap
Pump Stretch:
TPS Pump max:
TPS Pump Min
Pump Low Boost Scale PSI:
Boost Scaling:
RPM Limit:
Power Reduction:
0 PSI %:
1 PSI %:
2 PSI %:
3 PSI %:
4 PSI %:
5 PSI %:
6 PSI %:
7 PSI %:
8 PSI %:
9 PSI %:
10 PSI %:
11 PSI %:
12 PSI %:
13 PSI %:
14 PSI %:
15 PSI %:
16 PSI %:
18 PSI %:
20 PSI %:
22 PSI %:
24 PSI %:
26 PSI %:
28 PSI %:
30 PSI %:
My Mods
My Tunes
DD:
Quote
Power Levels: 6
Fuel Load Timing: 2
Low PSI Timing Reduct: 2
Timing Reduct Scaling: 100
Light Throttle Timing Adv:2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Fuel Stretch: 1700
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 8
Boost Scaling: 40
RPM Limit: 3500
Power Reduction: 15
0 PSI %:84
1 PSI %:84
2 PSI %:85
3 PSI %:86
4 PSI %:87
5 PSI %:88
6 PSI %:89
7 PSI %:90
8 PSI %:92
9 PSI %:94
10 PSI %:96
11 PSI %:98
12 PSI %:100
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Tow:
Quote
Power Levels: 6
Fuel Load Timing: 1
Timing vs rpm
1500: 16
2000: 19
2500: 24
3000: 26
Timing Max: 27
Fuel Stretch: 1400
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 5
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:92
1 PSI %:92
2 PSI %:94
3 PSI %:96
4 PSI %:96
5 PSI %95
6 PSI %:95
7 PSI %:96
8 PSI %:97
9 PSI %:98
10 PSI %:99
11 PSI %:100
12 PSI %:102
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Race:
Quote
Power Levels: 6
Fuel Load: 1.5
Low PSI Timing Reduct: 3
Timing Reduct Scaling:100
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Quote
Fuel Stretch: 1800
TPS Pump max: 100
TPS Pump Min 20
Boost Scaling: 40
RPM Limit: 3700
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
Quote
Power Levels: 6
Fuel Load Timing: 2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 0
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
Edited by Me78569
  • Replies 1k
  • Views 370.9k
  • Quadzilla Power
    Quadzilla Power
2 minutes ago, Me78569 said:
@xxTJRocksxx
Give me Videos or give me death!!!!
Please :whistle:
Errrr roger that, Videos to come on the way to work tomorrow.
So My tablet is android and I am an Avid google drive user. My tablet automatically uploads my data logs to my server when I pull into the Driveway lol.
My v2.2 tune is as follows
Power Levels: 6
Fuel Load Timing:2
Low PSI Timing Reduct:2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Pump Stretch: 1750
TPS Pump max: 100
TPS Pump Min 20
Boost Scaling: 40
RPM Limit: 3400
Power Reduction: 35
0 PSI %: 87
1 PSI %: 88
2 PSI %: 89
3 PSI %: 90
4 PSI %: 91
5 PSI %: 92
6 PSI %: 93
7 PSI %: 94
8 PSI %: 95
9 PSI %: 96
10 PSI %: 98
11 PSI %: 100
12 PSI %: 102
13 PSI %: 104
14 PSI %: 106
15 PSI %: 108
16 PSI %: 110
18 PSI %: 114
20 PSI %: 118
22 PSI %: 122
24 PSI %: 126
26 PSI %: 130
28 PSI %: 134
30 PSI %: 138
Edited by Me78569
@Me78569 You tune is really close to what I'm running.
As for other members posting Quadzilla tunes... I'm posting a blank tuner page (below) here now so you can cut and paste to fill in.
TUNE PARAMETERS
Number of Power levels:
RPM Limit:
VALET MODE PARAMETERS
Maximum Valet Mode Power:
PUMP TAP PARAMETERS
Maximum Fuel Stretch:
TPS Pump Maximum:
TPS Pump Minimum:
Boost Scaling:
TIMING PARAMETERS
Fuel Load Timing:
RPM TIMING MAX
1500 RPM:
2000 RPM:
2500 RPM:
3000 RPM:
Max:
BOOST LEVEL FUELING - CAN BUS
0 PSI:
1 PSI:
2 PSI:
3 PSI:
4 PSI:
5 PSI:
6 PSI:
7 PSI:
8 PSI:
9 PSI:
10 PSI:
11 PSI:
12 PSI:
13 PSI:
14 PSI:
15 PSI:
16 PSI:
18 PSI:
20 PSI:
22 PSI:
24 PSI:
26 PSI:
28 PSI:
30 PSI:
_____________________________
Now my tune... I'm going to test out on my next trip to Boise...
TUNE PARAMETERS
Number of Power levels: 7
RPM Limit: 3500
Maximum Valet Mode Power: 25%
PUMP TAP PARAMETERS
Maximum Fuel Stretch: 2000 microseconds
TPS Pump Maximum: 100
TPS Pump Minimum: 20
Boost Scaling: 40
TIMING PARAMETERS
Fuel Load Timing: 2
RPM TIMING MAX
1500 RPM: 16
2000 RPM: 18
2500 RPM: 23
3000 RPM: 25
Max: 26
BOOST LEVEL FUELING - CAN BUS (Using Exponential Growth of 1.3% starting with 100)
0 PSI: 100
1 PSI: 101
2 PSI: 102
3 PSI: 103
4 PSI: 105
5 PSI: 106
6 PSI: 108
7 PSI: 109
8 PSI: 110
9 PSI: 112
10 PSI: 113
11 PSI: 115
12 PSI: 116
13 PSI: 118
14 PSI: 119
15 PSI: 121
16 PSI: 122
18 PSI: 126
20 PSI: 129
22 PSI: 132
24 PSI: 136
26 PSI: 139
28 PSI: 143
30 PSI: 147
Edited by Me78569
@Mopar1973Man  still running 3* of cruise timing?  That will try to get timing at 20* when at cruise.
My stupid mind. :doh:
I was remembering the warmer weather and early version of timing numbers. Now my last trip I ran Lvl 0 and watch for nearly 50 miles of how the timing was in stock power. Then flipped back to mine and I was retarding fairly heavy. So I aimed for about 1-2* gain over stock roughly to start a base tune. Then I'll play more with it on this next trip down to Boise on Tuesday. So now you have to take in account of the weather, temperature, and IAT. This all changes things up a bit. So I'll work from just above stock to hopefully find that happy MPG spot again.
So I'm trying to understand the power levels when you custom tune, what exactly do they Mean for example when  you make level 6 is level 6 the level of the tune you just created or the amount of levels it takes to get to the to the max of that level?
More power levels don't mean more power, just a smaller bump in power per lvl.
Lvls 0-3 don't change so it's only lvls 4- whatever as your wiretap.
Like I use 7 power levels this gives me...
0 Stock
1 Reduced power
2 CANBus
3 CANBus
4 33% of wire tap.
5 66% of wire tap.
6 Full wire tap.
Remember you alway have to count ZERO as a number. So my power levels would just divide up the power even more into small amounts. So your affect the bold amount and how much your dividing the power per level.
  • 4 weeks later...
@JDHudsn tunes so far
Stock injectors.
Quote
DAILY
Power Levels: 6
RPM Limit: 3400
Maximum Valet Mode Power: 20%
Maximum Fuel Stretch: 1500
TPS Pump Maximum: 100%
TPS Pump Minimum: 25%
Minimum Pump Tap Fuel Precantage: 0%
Pump Low Boost Scale PSI: 10
Boost Scaling: 40
Max Load Timing Offset: 2
Timing Reduct Scaling: 100%
Timing vs rpm
1500: 17
2000: 19
2500: 23
3000: 25
Max: 26
0 PSI %: 100
1 PSI %: 102
2 PSI %: 102
3 PSI %: 103
4 PSI %: 105
5 PSI %: 106
6 PSI %: 108
7 PSI %: 109
8 PSI %: 110
9 PSI %: 112
10 PSI %: 113
11 PSI %: 115
12 PSI %: 116
13 PSI %: 118
14 PSI %: 119
15 PSI %: 121
16 PSI %: 122
18 PSI %: 126
20 PSI %: 129
22 PSI %: 132
24 PSI %: 136
26 PSI %: 139
28 PSI %: 143
30 PSI %: 147
Tow
Power Levels: 6
RPM Limit: 3200
Maximum Valet Mode Power: 15%
Maximum Fuel Stretch: 1700
TPS Pump Minimum: 20%
Boost Scaling: 40
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Max: 26
0 PSI %: 104
1 PSI %: 106
2 PSI %: 108
3 PSI %: 110
4 PSI %: 112
5 PSI %: 114
6 PSI %: 116
7 PSI %: 118
8 PSI %: 120
9 PSI %: 122
10 PSI %: 124
11 PSI %: 126
12 PSI %: 128
13 PSI %: 130
14 PSI %: 132
15 PSI %: 134
16 PSI %: 136
18 PSI %: 138
20 PSI %: 140
22 PSI %: 142
24 PSI %: 144
26 PSI %: 146
28 PSI %: 148
30 PSI %: 150
Economy
Power Levels: 6
RPM Limit: 3200
Maximum Fuel Stretch: 1200
Minimum Pump Tap Fuel Precantage: 5%
Boost Scaling: 40
Timing vs rpm
1500: 17
2000: 19
2500: 23
3000: 25
Max: 26
0 PSI %: 100
1 PSI %: 102
2 PSI %: 103
3 PSI %: 105
4 PSI %: 106
5 PSI %: 108
6 PSI %: 109
7 PSI %: 110
8 PSI %: 112
9 PSI %: 112
10 PSI %: 115
11 PSI %: 116
12 PSI %: 118
13 PSI %: 119
14 PSI %: 121
15 PSI %: 122
16 PSI %: 126
18 PSI %: 129
20 PSI %: 132
22 PSI %: 136
24 PSI %: 139
26 PSI %: 144
28 PSI %: 147
30 PSI %: 150
Fun
Power Levels: 6
RPM Limit: 3400
Maximum Fuel Stretch: 2200
TPS Pump Minimum: 0%
Minimum Pump Tap Fuel Precantage: 50%
Boost Scaling: 40
Max Load Timing Offset: 3
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Max: 26
0 PSI %: 101
1 PSI %: 103
2 PSI %: 105
3 PSI %: 107
4 PSI %: 110
5 PSI %: 113
6 PSI %: 116
7 PSI %: 119
8 PSI %: 122
9 PSI %: 125
10 PSI %: 128
11 PSI %: 131
12 PSI %: 134
13 PSI %: 137
14 PSI %: 140
15 PSI %: 143
16 PSI %: 146
18 PSI %: 149
20 PSI %: 150
22 PSI %: 150
24 PSI %: 150
26 PSI %: 150
28 PSI %: 150
30 PSI %: 150
Edited by Me78569
Might take a peek at my economy tune as well. I've been keeping the Excel up to date when I make changes.
  • 3 weeks later...
@Me78569 and @TFaoro What's up guys, I love the 2.2 tuning, I just wish the App was easier to use.
I have a friend with a built 2002 automatic, running a quad 4k box. He's running 7x14 injectors with a 188/220 cam, and S366/S475 crazy carls compounds. I am trying to get him on the forum here.
Can his 4k box run the hard fuel v2.2 tuning?
@TFaoro, what kind of tune are you running for daily and race?
Also a couple observations I made with the new tuning:
Big injectors do not automatically determine the back down in canbus fuel, I say this because my DD tune I start my canbus % at 82% and cruise timing is only 1* but recently I have been running a highway tune which the canbus % starts at 100%, but the timing is 4*. What I discovered is that because of injector size, timing is very important for the smoke control. The fuel needs more time to atomize and light off. also when reducing % of canbus fuel, the truck will respond better to less timing since we are bringing the fueling closer to stock. So far I get no smoke dding and almost none when I pass people on the highway. I seem to be averaging 22-24 mpg combined on my commutes.
Emissions Tune,  %100 smoke free even with wiretap on
Quote
Power Levels:6
Timing
Fuel Load Timing: 2
Low PSI Timing Reduct: 4
Light Throttle Timing Adv: 2
Timing vs rpm
1500: 15
2000: 18
2500: 22
3000: 24
Timing Max: 25
Wiretap
Pump Stretch: 1200
TPS Pump max: 100
TPS Pump Min: 0
Minimum Pump Tap Fueling Percentage: 0
Pump Low Boost Scale PSI: 12
Boost Scaling: 40
RPM Limit: 3200
Power Reduction: 80
0 PSI %: 80
1 PSI %:  80
2 PSI %: 81
3 PSI %: 82
4 PSI %: 83
5 PSI %: 84
6 PSI %: 85
7 PSI %: 86
8 PSI %: 87
9 PSI %: 88
10 PSI %:89
11 PSI %: 90  **where wiretap comes in
12 PSI %: 90 **where wiretap comes in
13 PSI %: 90 **where wiretap comes in
14 PSI %: 91
15 PSI %: 92
16 PSI %: 94
18 PSI %: 96
20 PSI %: 98
22 PSI %: 100
24 PSI %: 104
26 PSI %: 108
28 PSI %: 112
30 PSI %: 116
Note the 11 - 13 psi range how I did not increase canbus fueling.  This is so that when wiretap starts to apply we have a smooth increase in fueling and no smoke.  Once wiretap is started you can then start adding more canbus.  Keep in mind that all you need to hit the max fueling of 4095 is about 115% up top.
this tune still makes good power, prob north of 350 hp on my truck but is %100 smoke / haze free regardless of what you do with the pedal at ANY point in time.
My emissions tests are snap tests at
35 mph
45 mph
55 mph
65 mph
I am allowed up to %20 opacity,  the smarty set to half power mode did %7 last year.   My visible emissions are less this year from what I can see in the tailpipe, but I am required to do testing within the next month I think.
Also keep in mind Colorado Springs is at 6500' where I get tested so the %20 is really low for our altitude, last time I checked even Cali was allowing %30....
Edited by Me78569
I have what feels like a miss or bucking when I have my Tow tune in. I think it has to do with timing. With the quad set to level 0 is goes away.
Happens in 6th gear with 48%+ engine load between 50-60 and timing is 15-16.
Power Levels:7
Timing
Fuel Load Timing: 0 (Max load timing offset?)
Low PSI Timing Reduct: .5
Light Throttle Timing Adv: .5
Light Throttle Timing Load Limit: 40
Timing vs rpm
1500: 14
2000: 16
2500: 23
3000: 25
Timing Max: 26
Wiretap
Pump Stretch: 1900
TPS Pump max: 100
TPS Pump Min: 35
Pump Low Boost Scale PSI: 15
Boost Scaling: 40
RPM Limit: 3200
Power Reduction: 25
0 PSI %: 100
1 PSI %:  101
2 PSI %: 102
3 PSI %: 103
4 PSI %: 105
5 PSI %: 106
6 PSI %: 108
7 PSI %: 109
8 PSI %: 110
9 PSI %: 112
10 PSI %:113
11 PSI %: 115
12 PSI %: 116
13 PSI %: 118
14 PSI %: 119
15 PSI %: 121
16 PSI %: 122
18 PSI %: 126
20 PSI %: 129
22 PSI %: 132
24 PSI %: 136
26 PSI %: 136
28 PSI %: 136
30 PSI %: 136
Edited by Me78569
Power Levels:7
Timing
Light Throttle Timing Adv: 1
Timing vs rpm
1500: 14
2000: 16
2500: 23
3000: 25
Timing Max: 26
Wiretap
Pump Stretch: 1900
TPS Pump max: 100
TPS Pump Min: 35
Boost Scaling: 40
RPM Limit: 3200
Power Reduction: 25
0 PSI %: 100
1 PSI %:  101
2 PSI %: 102
3 PSI %: 103
4 PSI %: 105
5 PSI %: 106
6 PSI %: 108
7 PSI %: 109
8 PSI %: 110
9 PSI %: 112
10 PSI %:113
11 PSI %: 115
12 PSI %: 116
13 PSI %: 118
14 PSI %: 119
15 PSI %: 121
16 PSI %: 122
18 PSI %: 126
20 PSI %: 129
22 PSI %: 132
24 PSI %: 136
26 PSI %: 136
28 PSI %: 136
30 PSI %: 136
What level(s) is it surging on?
A few things I see: Why do you have timing reduction at 5* and 100%??? You definitely don't need that, especially with the stock turbo and bigger injectors.
Your fuel stretch is huge.... I would back that down to 12-1500, especially for towing.
Edited by Me78569
Can you attach a data log of this event?  We need to see what everything is doing.
.5 not 5
Working on finding my log.
Not the log I am looking for but might work.
iQuad-2017-03-15-12.06.14-39167966.csv - iQuad-2017-03-15-12.06.14-39167966.csv.csv
Edited by 903Dodge
Something doesn't make sense in that log.  I am seeing you got WOT but canbus fueling is not increasing nor is rpm.
Are you hooked up to a heavy load in this log?   What level is the Quad on?
Edited by Me78569
Maybe gross 7k.
I don't think that is the log I was looking for. It may have to wait till I pull again.
I have noticed since we updated my box that idle timing had went from 13 to 11 when truck is warmed up.
I will I'll try to get a log for 60mph again so I can have something to compare it to.
I still haven't seen cruise timing come in.
