Quadzilla V2 Custom Tunes
Quote
Power Levels:
Timing
Fuel Load Timing:
Low PSI Timing Reduct:
Timing Reduct Scaling:
Light Throttle Timing Adv:
Timing vs rpm
1500:
2000:
2500:
3000:
Timing Max:
Wiretap
Pump Stretch:
TPS Pump max:
TPS Pump Min
Pump Low Boost Scale PSI:
Boost Scaling:
RPM Limit:
Power Reduction:
0 PSI %:
1 PSI %:
2 PSI %:
3 PSI %:
4 PSI %:
5 PSI %:
6 PSI %:
7 PSI %:
8 PSI %:
9 PSI %:
10 PSI %:
11 PSI %:
12 PSI %:
13 PSI %:
14 PSI %:
15 PSI %:
16 PSI %:
18 PSI %:
20 PSI %:
22 PSI %:
24 PSI %:
26 PSI %:
28 PSI %:
30 PSI %:
My Mods
My Tunes
DD:
Quote
Power Levels: 6
Fuel Load Timing: 2
Low PSI Timing Reduct: 2
Timing Reduct Scaling: 100
Light Throttle Timing Adv:2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Fuel Stretch: 1700
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 8
Boost Scaling: 40
RPM Limit: 3500
Power Reduction: 15
0 PSI %:84
1 PSI %:84
2 PSI %:85
3 PSI %:86
4 PSI %:87
5 PSI %:88
6 PSI %:89
7 PSI %:90
8 PSI %:92
9 PSI %:94
10 PSI %:96
11 PSI %:98
12 PSI %:100
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Tow:
Quote
Power Levels: 6
Fuel Load Timing: 1
Timing vs rpm
1500: 16
2000: 19
2500: 24
3000: 26
Timing Max: 27
Fuel Stretch: 1400
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 5
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:92
1 PSI %:92
2 PSI %:94
3 PSI %:96
4 PSI %:96
5 PSI %95
6 PSI %:95
7 PSI %:96
8 PSI %:97
9 PSI %:98
10 PSI %:99
11 PSI %:100
12 PSI %:102
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Race:
Quote
Power Levels: 6
Fuel Load: 1.5
Low PSI Timing Reduct: 3
Timing Reduct Scaling:100
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Quote
Fuel Stretch: 1800
TPS Pump max: 100
TPS Pump Min 20
Boost Scaling: 40
RPM Limit: 3700
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
Quote
Power Levels: 6
Fuel Load Timing: 2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 0
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
Edited by Me78569
  • Replies 1k
  • Views 379.4k
  • Quadzilla Power
    Quadzilla Power
I'll take few pictures when I can, I'm not by the truck now, and it may be few days, but it says right on it hx35w, my guess is luck was on my side.
It has a waste gate and it's been stock shut for about 4 years now. I freed it up when I was putting exhaust break on, but after a month or so it quit working again. So I've been trying to stay below 40, and most of time try not to go over 30. But this run was wot with can bus maxed out and wire tap at 2000. Boost shut up so fast past 40, I was like :wow:, had it flored in each gear for about 3 seconds. Starting in 2nd. Fuel pressure dropped to 16 from 18-19, usually I only see 1psi swing.
Ah that explains it.  Yeah, you sure are lucky.  Like Nick said, I would confirm with a mechanical gauge what the actual boost levels are.  My Quad has given me boost values of 50+ psi before, and the mechanical gauge said it was 43 psi...
I think I'll just lay off my Racing tune for a while, maybe if I ever figure out which turbo I want to go with. Plus I don't want to change my hx35 just because, it still works great. When time comes to rebuilding it, I'll see what I have and if it's just a regular hx35 I'll look into hybrid or other.  I was just mainly wondering if it was even possible to hit 50 psi with an hx35.
On 3/29/2017 at 10:32 PM, Me78569 said:
tell tail sign of the ecm memory doing hte way of the buffalo.
The WTS light is the light to show that the ecm is turning on. Think of the WTS light as
Well guys unfortunately the new MAP sensor didn't fix the issue. Quad is still logging fluctuating boost pressures. Still need to check the wires really good from the ecm but other that that anyone have anything else that could help?
12 hours ago, Me78569 said:
still having WTS light delay?
Yeah, it takes about 7s after key on for the pump to prime.
*will count actual seconds tomorrow
I hate to be the bear of bad news, but the V2 isn't going to work well with your dying ECM.   The V2 relies too much on solid sensor input that the ECM doesn't appear to be giving you.   If it was anything but the WTS being delayed I would say you shoudl dig more, but the WTS issue is pretty damning.
You can revert back to the older tunes, they should work better as they read from the Map sensor directly since they don't need filtered reads to have smooth fueling.
However I would serously consider looking for a new ecm before you are left somewhere.
Anyone you recommend getting a new ecm from? eBay? Geno's? Or find a cummins dealer?
thanks for your help
On 4/3/2017 at 7:31 AM, Dieselfuture said:
       Had some time this weekend to play with a racing tune. Over all it worked well I though, some to minimal smoke and good power. Although I had my Boost defuel set at 37psi and EGT at 1300, data logging said I was at 49psi and 1500 egt. I may reduce it to 32 and 1100 and see how it defuels.
Hey Dieselfuture, What revision of the base code are you using? If you look at the sensor data, you should see something that says Build Date, that is going to report the revision of the base code and may look  something like 20170217 or something similar. You want to make sure that you are using 20170315 or greater to make sure that  you have the backdown bug fixed. That could be why you are blowing right past your backdowns.
@Quadzilla Power I will double check, thanks. Pretty sure I updated it to most recent. Never know though.
Any ideas why my quad BT loses conection sometimes, just says device conection lost or something like that.
Edited by Dieselfuture
I'm not sure about that. It could be any number of things from random electrical noise, to your phone dropping it, to electro-magnetic interference from overhead power lines.As long as the BT unit has power and is receiving a signal from the Adrenaline, it should give you a pretty strong signal. You might try moving the location of the BT module and see if it helps.
Check to see if your box has a jumper installed in the pins like the ones circle in the picture below.  98.5-00 trucks should not have a jumper, 01-02 trucks should have it, to make the boost read right
2 minutes ago, thatblackvptruck said:
I have a iquad and for some reason my truck shows it's building 4 pounds of boost at idle any suggestions
Kind of like mine showing 2 PSI of boost with the key on and engine off.
That's what the ECM is likely seeing as sensor input.  What year truck is it?
It's a sensor input so if the sensor is incorrect then the reading is incorrect.  0-2 psi is normal 4 psi is high.
Test your sensor.  I would assume your sensor is old and it is not able to read under 4 psi.
On 11/7/2016 at 4:21 PM, Mopar1973Man said:
I'm running only 6* of timing. Then my low boost scale is set for 25%. I've taken a stock tune and tweaked it to my own liking.
Power Levels: 7
Fuel Load timing: 2
Light Throttle Timing Adv: 2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Fuel Stretch: 1400  ** turn this up if you need more power up top
TPS Pump max: 100
TPS Pump Min 20
Boost Scaling: 38
RPM Limit: 3200
Power Reduction: 5 (Barely pulls at 5 MPH great security feature)
0 PSI %: 100
1 PSI %: 102
2 PSI %: 104
3 PSI %: 106
4 PSI %: 108
5 PSI %: 110
6 PSI %: 112
7 PSI %: 114
8 PSI %: 116
9 PSI %: 118
10 PSI %: 120
11 PSI %: 122
12 PSI %: 124
13 PSI %: 126
14 PSI %: 128
15 PSI %: 130
16 PSI %: 132
18 PSI %: 134
20 PSI %: 136
22 PSI %: 138
24 PSI %: 140
26 PSI %: 142
28 PSI %: 144
30 PSI %: 146
Hey guys, brand new member here.
Im at a complete loss, with the fear of sounding dumb, im totally clueless with this V2 tuning.  Ive read everything on here and on the v2 tuning page.  But for some reason im having trouble understanding it all.  Ive never tuned before.
So in order to get a little help here, i used the tune that ive quoted in my truck the other night.  EXCESSIVE smoke.  Very high EGTs, and some popping.
So im asking for a little bit of guidance feom you guys.  Spencer at quadzilla told me to look u guys up.  Im willing to learn, dont really want to come in here and have everything handed to me on a silver platter.  Just trying to get this truck dialed in, without melting it down in the meantime.  I have edited my profile so u guys can see what i ha e dont to my rig.  Im also trying to upload my url to my profile so u can watch a cpl videos on my youtube channel to better understand my issues.
So, with all that being said, can yall give me a hand with getting a good tune set up?
Edited by Me78569
@TJ_00Cummins with bigger injectors like you have you want to start your 0 psi at maybe 80% or so to get smoke cleared up.
Try this one, it's something @Me78569 posted in the beginning of this thread
Power Levels: 6
Fuel Load Timing: 2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Fuel Stretch: 1700
TPS Pump max: 100
TPS Pump Min 20
Boost Scaling: 40
RPM Limit: 3500
Power Reduction: 15
0 PSI %:84
1 PSI %:84
2 PSI %:85
3 PSI %:86
4 PSI %:87
5 PSI %:88
6 PSI %:89
7 PSI %:90
8 PSI %:92
9 PSI %:94
10 PSI %:96
11 PSI %:98
12 PSI %:100
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Edited by Me78569
Use valet mode power to find your starting point.  set the Quad to lvl 1, then set valet mode power at 75%.  From a stop stomp on it,
It is slow? If so increase the % until you are happy with the trade off of smoke vs power.
Once you have a starting % build the rest of the tune from there.
Your timing will have to be ~2* lower at 2k - max to not pop
