Quadzilla V2 Custom Tunes
Quote
Power Levels:
Timing
Fuel Load Timing:
Low PSI Timing Reduct:
Timing Reduct Scaling:
Light Throttle Timing Adv:
Timing vs rpm
1500:
2000:
2500:
3000:
Timing Max:
Wiretap
Pump Stretch:
TPS Pump max:
TPS Pump Min
Pump Low Boost Scale PSI
Boost Scaling:
RPM Limit:
Power Reduction:
0 PSI %:
1 PSI %:
2 PSI %:
3 PSI %:
4 PSI %:
5 PSI %:
6 PSI %:
7 PSI %:
8 PSI %:
9 PSI %:
10 PSI %:
11 PSI %:
12 PSI %:
13 PSI %:
14 PSI %:
15 PSI %:
16 PSI %:
18 PSI %:
20 PSI %:
22 PSI %:
24 PSI %:
26 PSI %:
28 PSI %:
30 PSI %:
My Mods
My Tunes
DD:
Quote
Power Levels: 6
Fuel Load Timing: 2
Low PSI Timing Reduct: 2
Timing Reduct Scaling: 100
Light Throttle Timing Adv:2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Fuel Stretch: 1700
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 8
Boost Scaling: 40
RPM Limit: 3500
Power Reduction: 15
0 PSI %:84
1 PSI %:84
2 PSI %:85
3 PSI %:86
4 PSI %:87
5 PSI %:88
6 PSI %:89
7 PSI %:90
8 PSI %:92
9 PSI %:94
10 PSI %:96
11 PSI %:98
12 PSI %:100
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Tow:
Quote
Power Levels: 6
Fuel Load Timing: 1
Timing vs rpm
1500: 16
2000: 19
2500: 24
3000: 26
Timing Max: 27
Fuel Stretch: 1400
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 5
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:92
1 PSI %:92
2 PSI %:94
3 PSI %:96
4 PSI %:96
5 PSI %95
6 PSI %:95
7 PSI %:96
8 PSI %:97
9 PSI %:98
10 PSI %:99
11 PSI %:100
12 PSI %:102
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Race:
Quote
Power Levels: 6
Fuel Load: 1.5
Low PSI Timing Reduct: 3
Timing Reduct Scaling:100
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Quote
Fuel Stretch: 1800
TPS Pump max: 100
TPS Pump Min 20
Boost Scaling: 40
RPM Limit: 3700
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
Quote
Power Levels: 6
Fuel Load Timing: 2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 0
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
Edited by Me78569
  • Replies 1k
  • Views 347.7k
  • Quadzilla Power
    Quadzilla Power
Oh ok.  Well,i will leave it all alone then.  I did notice after i got my new box from Quadzilla, the wuad was reading around 4psi low on the tablet as compared to my mechanical guage.
Also, i was reading a few pages back where me78569 said moparman was a rebel for not having studs.  Kinda laughed as im not running studs yet either.  270k miles, factory seal, 60psi and still sporting factory bolts lol:cool:
aint broke dont fix it right?
5 minutes ago, Me78569 said:
Yes switch to 2.5,  that will make your tunes exportable and importable from the tune builder excel macro @Carbur8tr built
Ok will do! Thanks! Truck has been running pretty damn good lately.  Had to replace the off brand triple disc converter last week.  Went with a Goerends triple disc.  LOVE it! The ol 47re should be pretty good to go now.  All billet shafts except the intermediate.
Was hoping to hit the strip on last time to shoot for 11s in the truck but dont think ill get a chance.
glad the truck is running well.  I am really happy with my current tune as well.
Thats my thought.  I will be upgrading valvetrain and studs over the winter.  Gonna slap an s475 with my 366.  Run the VP till she finally goes then p-pump swap.
Yea, me too man.  Would have loved to put down 600+ on the dyno, but didnt want to flirt with the timing.  Max is at 26 right now.  595hp.  Hell, probably just another degree would have done it.  But im trying respect the gasket.  Lol
What would everyone consider the highest timing that is safe for a
dd tune (that I occasionally rod on) at cruising rpm (1750)
Towing tune
Race tune
Currently on my dd tune I'm running 21.5-22 actual ( 62mph) and it runs good, I can "hear" the high timing..
Yes I do have studs
That's going to take a Heck of injector with a 66mm isn't it? Lol
Yea, ive got 6x018s right now, so we will see how they do.  Lol kinda just pushing my luck but a swap is in the plans, just gonna see what i can get out of the vp lol
Lol that should be enough I guess ha ha
If you have studs I wouldn't worry about timing.  Increase it until you feel the truck be kinda lazy then back down timing some.
My truck likes 20-21* at 65 mph
Then set your light load limit about 5% higher than your cruise load.  Then do fuel load of ~2*that should get you into the meatof the timing curve when you put the pedal down.
What about trucks without head studs what timing range are we looking at then? Thanks
dd tune
I run as high as 25* of timing at 80 mph (2150 rpm)  Truck seems to love it.
At 60-65 mph I run 22-23* of timing and that's where I see my highest MPG's.  But your truck might like something different.
Edited by trreed
Over 2.5k I dont think it is possible to overtime a vp44 truck
I would ensure your tunes have fuel load set to at least 1.5* and your light throttle load limit % should be %5 over your cruise load.
as for a safe curve in the rpm timing setup
I would go no higher than 17* at 1500, 20 at 2k and 23 at 2.5k
I just set mine to 1º higher than all these right before you posted this.. Maybe I should back off 1/2º but I still haven't hit a spot that it seems to lull or leg
Im on factory bolts and gasket.
I run   1500rpm 17.5
           2000rpm 19.5
           2500rpm 23.0
           3000rpm 24.5
           Max.        26.0
Ive been like that for quite some time now.  Runs great.
I run   1500rpm 17.5
           2000rpm 19.5
           2500rpm 23.0
           3000rpm 24.5
           Max.        26.0
I'm at
18
21
23.5
26.2
29
Load timing offset 2.5
Low psi reduct 2.5
Reduct salon scaling 100
Light advance 5
Load limit 32
Pretty high but It runs ok
I wouldn't worry about it until you have lul in torque with timing.
Factory bolts then I error on the side of safe vs performance.
:thumb1: I think I'll stay where im at for a few tanks of fuel see how she does... I'm up 1.5º from where I was yesterday
1 hour ago, Dodgeih said:
Load timing offset
Low psi reduct
Timing reduct scaling
Light advance
Load limit
@Me78569 I want to better educate myself on these parameters. Where can I read about each one and how they effect how my truck?
have you read the tune article I wrote?  how about the video  I created?
