Quadzilla V2 Custom Tunes
Quote
Power Levels:
Timing
Fuel Load Timing:
Low PSI Timing Reduct:
Timing Reduct Scaling:
Light Throttle Timing Adv:
Timing vs rpm
1500:
2000:
2500:
3000:
Timing Max:
Wiretap
Pump Stretch:
TPS Pump max:
TPS Pump Min
Pump Low Boost Scale PSI
Boost Scaling:
RPM Limit:
Power Reduction:
0 PSI %:
1 PSI %:
2 PSI %:
3 PSI %:
4 PSI %:
5 PSI %:
6 PSI %:
7 PSI %:
8 PSI %:
9 PSI %:
10 PSI %:
11 PSI %:
12 PSI %:
13 PSI %:
14 PSI %:
15 PSI %:
16 PSI %:
18 PSI %:
20 PSI %:
22 PSI %:
24 PSI %:
26 PSI %:
28 PSI %:
30 PSI %:
My Mods
My Tunes
DD:
Quote
Power Levels: 6
Fuel Load Timing: 2
Low PSI Timing Reduct: 2
Timing Reduct Scaling: 100
Light Throttle Timing Adv:2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Fuel Stretch: 1700
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 8
Boost Scaling: 40
RPM Limit: 3500
Power Reduction: 15
0 PSI %:84
1 PSI %:84
2 PSI %:85
3 PSI %:86
4 PSI %:87
5 PSI %:88
6 PSI %:89
7 PSI %:90
8 PSI %:92
9 PSI %:94
10 PSI %:96
11 PSI %:98
12 PSI %:100
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Tow:
Quote
Power Levels: 6
Fuel Load Timing: 1
Timing vs rpm
1500: 16
2000: 19
2500: 24
3000: 26
Timing Max: 27
Fuel Stretch: 1400
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 5
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:92
1 PSI %:92
2 PSI %:94
3 PSI %:96
4 PSI %:96
5 PSI %95
6 PSI %:95
7 PSI %:96
8 PSI %:97
9 PSI %:98
10 PSI %:99
11 PSI %:100
12 PSI %:102
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Race:
Quote
Power Levels: 6
Fuel Load: 1.5
Low PSI Timing Reduct: 3
Timing Reduct Scaling:100
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Quote
Fuel Stretch: 1800
TPS Pump max: 100
TPS Pump Min 20
Boost Scaling: 40
RPM Limit: 3700
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
Quote
Power Levels: 6
Fuel Load Timing: 2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 0
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
Edited by Me78569
  • Replies 1k
  • Views 336.6k
  • Quadzilla Power
    Quadzilla Power
They want circumference of the tire. 103 inches
How did you get that number?
https://tiresize.com/calculator/
Circumference = Pi x Diameter
55 minutes ago, Mopar1973Man said:
32 Inches... Basically gaining 1 full inch over me. But more rotational weight...
285mm = 11.2205 x 75% = 8.41 inch x 2 =16.83 + 16 Rim = 32.8 Inch tall tire. 102.9" (32.8" x 3.14)
Just like 235/85 R16...
235mm = 9.25197 x 85% = 7.86 inches x 2 = 15.72 + 16 Rim = 31.7 inch tall tire. 99.5" (31.7" x 3.14)
Or 265/75 R16...
265mm = 10.4331 x 75% = 7.82 inches x 2 = 15.64 + 16 Rim = 31.6 Inch tall tire. 99.2" (31.6" x 3.14)
Then rev per miles...
Take the Circumference and divide by 63360 (inches in a mile).
63360 / 102.9" = 615.74 Revs per mile.
Math goes a long ways...
Hey guys.  Just installed the quad on my 99.  I’ve never dealt with wire tap fueling as I’ve only used a power puck and then a smarty.  I have 7x.0085 sac injectors and stock hx35w.  I’m in the process of building my dd tune and made an observation I’m hoping y’all can help clarify.
At lvl 3 I’ll get the full canbus fueling when trying to accelerate to pass someone.  Once in level 4 of 6, same conditions I’ll only see about 2800-2900 canbus but I’ll be blowing the doors off the thing.  My guess is...with the wiretap I’m using less tps but getting same or more fuel from the wiretap.  I’m just trying to learn why things work the way they do.  Thanks!
What do you have for the wiretap settings? List them out I can help you out.
Just running my Economy Tune which has the wiretap at 1,200 and TPS start at 30% and TPS end at 100% This thing is sick when I bounced around a Ford Truck in 4th gear and the tire break loose and had to drop the throttle, upshift and started pull again and cleared the nose of him by 85 MPH. I was moving.
I’m away from the truck for the evening I’ll post up my tune so far when I get home from work in the morning.
I thought I smelled pizza!  Wind was blowing hard enough to bring the smell all the way down to Denver
you are correct, wiretap will add for fuel for the same tps input.  canbus fueling is very much related to tps
28 minutes ago, notlimah said:
Sounds more like a race tune to me Mike! Watch out now!
My performance tune is stupid. It got some smoke but really easy to get the tires to break loose. Damn boost gauge snaps 45 PSI just as quick as the wiretap hits. That is a 1,600us wiretap pulse. My Economy tune has the wiretap turned down to the minimum it just doesn't get any lower than 1,200us for the wiretap. The economy tune is clean, just light puffs as the turbo spools. Both tunes are running bit more retard on the 1,500 RPM band once I get 2,000 RPM band it steps up and we get motorvating... (Pun intended!)
Economy tune is like my sleeper tune nobody expects a stock tire truck with stock wheels, etc to flat haul :moon: . That tune is clean so I get Ford and Chevy always wanting to play. Most of them don't like the outcome.  Now the Performance tune has smoke so its a dead give away I've got something to give. Either case I can't keep the tires under the truck either tune is capable of smoking the tires on smooth road surface. Like the fresh chip-coat up here at home, it stays hooked up on the pavement. Smooth city streets can get rather dicey sometimes.
Are you referring to the pump stretch here?
Also, on the app, is the gear indicator and lock up indicator supposed to work on our trucks?  Or is that for the newer vehicles?  Mine shows whatever gear it wants and never shows lockup.
Might have to start a race truck section
:burnout:
Here is my wire tap settings.
I think I need to raise the tps pump min to 30%.  At 64 mph I’m at 20% tps and engine load.
At 64 I’m at 5-7psi on the quad and 6-8 on the isspro.  Level three has zero wiretap correct?  Or is it level two now with the update?
Level 3 is 0 wiretap, full range of CANBus fueling.  Your wiretap won't kick on until both 20% throttle input and 10 psi of boost are met.
EDIT: Just noticed your min pump tap fuel percentage is 5%.  That means there's always 5% wiretap when using your wiretap levels.
Edited by trreed
Thank you for clarifying that.  I was reading Me’s how to tune thread and it said level three was canbus only then down the page more it said level three had wiretap.  Got confused.
I like the 5% min pump tap%.  Truck is very responsive to it.  I’ve def out grown the hx35 now though.
Edit: I asked earlier prolly got lost, but does the gear & lock up indicators not work for our generation trucks?
Edited by Mr. Bojangles
Added question
Drop the 5% minimum pump tap to 0%.
Push the Boost scaling up to 30 to 40 for sure.
Minimum TPS should be pushed up to 30% I like 50% minimum being you stay out of the wiretap for daily driving.
They should.  have you set up your drivetrain info under settings?
min wiretap % only applies if tps mins and boost mins are met.
V2 lvl4+  has wiretap V1 lvl 3+
