Quadzilla V2 Custom Tunes
Quote
Power Levels:
Timing
Fuel Load Timing:
Low PSI Timing Reduct:
Timing Reduct Scaling:
Light Throttle Timing Adv:
Timing vs rpm
1500:
2000:
2500:
3000:
Timing Max:
Wiretap
Pump Stretch:
TPS Pump max:
TPS Pump Min
Pump Low Boost Scale PSI
Boost Scaling:
RPM Limit:
Power Reduction:
0 PSI %:
1 PSI %:
2 PSI %:
3 PSI %:
4 PSI %:
5 PSI %:
6 PSI %:
7 PSI %:
8 PSI %:
9 PSI %:
10 PSI %:
11 PSI %:
12 PSI %:
13 PSI %:
14 PSI %:
15 PSI %:
16 PSI %:
18 PSI %:
20 PSI %:
22 PSI %:
24 PSI %:
26 PSI %:
28 PSI %:
30 PSI %:
My Mods
My Tunes
DD:
Quote
Power Levels: 6
Fuel Load Timing: 2
Low PSI Timing Reduct: 2
Timing Reduct Scaling: 100
Light Throttle Timing Adv:2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Fuel Stretch: 1700
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 8
Boost Scaling: 40
RPM Limit: 3500
Power Reduction: 15
0 PSI %:84
1 PSI %:84
2 PSI %:85
3 PSI %:86
4 PSI %:87
5 PSI %:88
6 PSI %:89
7 PSI %:90
8 PSI %:92
9 PSI %:94
10 PSI %:96
11 PSI %:98
12 PSI %:100
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Tow:
Quote
Power Levels: 6
Fuel Load Timing: 1
Timing vs rpm
1500: 16
2000: 19
2500: 24
3000: 26
Timing Max: 27
Fuel Stretch: 1400
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 5
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:92
1 PSI %:92
2 PSI %:94
3 PSI %:96
4 PSI %:96
5 PSI %95
6 PSI %:95
7 PSI %:96
8 PSI %:97
9 PSI %:98
10 PSI %:99
11 PSI %:100
12 PSI %:102
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Race:
Quote
Power Levels: 6
Fuel Load: 1.5
Low PSI Timing Reduct: 3
Timing Reduct Scaling:100
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Quote
Fuel Stretch: 1800
TPS Pump max: 100
TPS Pump Min 20
Boost Scaling: 40
RPM Limit: 3700
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
Quote
Power Levels: 6
Fuel Load Timing: 2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 0
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
Edited by Me78569
  • Replies 1k
  • Views 326.4k
  • Quadzilla Power
    Quadzilla Power
33 minutes ago, rogerash0 said:
My quadzilla fuel pressure gauge showing 47-50psi when I have 18-20psi actual is the real fail..
I am having the opposite.  My quad says 11psi less than my mechanical gauge. Have you replaced your map sensor lately?
11 psi difference in map values suggests to me that the jumper inside the quad is not setup for your year range.
On 5/8/2018 at 10:07 AM, Mopar1973Man said:
If people are so good at tracking people why is it so hard for law enforcement to trackdown criminals and put them away?
Because $$$. Tracking down criminals is not a profitable job.
ADR1000. My truck is a 2000. But...... my pcm is from a 01. Moparman says it shouldnt matter. I should check my wiring. That's next. .....
I also just replaced the map. I think maybe the map sensor is not putting out right readings or maybe a bad wire or connection somewere. Does anyone have wiring diagram? I may just rewire it.
Check the articles there are full wiring diagrams.
11 psi is the exact offset for late vs early trucks.  I'd check the jumper inside the box
Does anyone  have a replacement fuel pressure  sensor part# does the quad need a snubber ? i hooked my quad harness into my glowshit sending unit & it reads 5 psi , in other progress bumped my cruise timing up so im at 19.5° and  pulled 21 mpg!
Edited by MoparLevi
It will read incorrectly if you are not running one of our fuel pressure sending units. The edge ones will usually read in that range or higher.
I just went through this. You have to have the snubber. I blew diesel out the back of my sensor thorough the plug. Call glowshift. They will send you a new sensor if you are nice. But you will have to buy the snubber.
Also.... I talked to the quadzilla guy on here and he said that the quadzilla sensor is probably different readings and that the glowshift sensor may plug in but may give wrong readings.
Yes, you need to use the snubber. VP44s are notorious for sending very high pressure spikes back on the feed lines. These sensors are rated from 0 to 100psi, but they can't handle the 4000psi spike the gets kicked back. The snubber valve knocks those down and acts like a low pass psi filter. In other words, stuff that changes slowly will get passed onto the sensor, a very high, very quick, and low duration spike that might last less than a millisecond will get knocked down by the snubber and that pressure spike won't make it to the sensor.
Where did you get your map from? I got one from NAPA before I bought the quad. Turns out the map was reading wrong so I put the stock map sensor back in and everything went back to normal.
My original went bad.... Bench tested and it was putting full 5v through. I bought 1 from ebay and it lasted 10 days. This one is from Advanced auto. I posted on the forums asking about a Cummins part. No one knew. I do know that the 01 has different voltage output signals. I thought maybe my 01 PCM was the issue.
Need a part number? there's a article for that
https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/part-number-lookup-tool-2nd-gen-24v/
How can i get one of your sending units, i don't see them on the website, i this quad from a buddy 5 years ago & i never got one with it
@MoparLevi I will send you a PM
17 hours ago, Me78569 said:
I checked the article and the number given is a unicorn. There is 1 on ebay but looks used. Not new parts on the ol interweb thing lol. There are many cheap parts that say they work but I have had very little luck with either one. 1 popped in 10 days and this one is giving wrong readings. I am gonna try the grounds tonight. S165 looks like the one.  Near the oil sending unit. Right?
1 minute ago, Mopar1973Man said:
@Raffron What year of truck? It's not in your signature...
2000 sorry I will change that.
