Quadzilla V2 Custom Tunes
Quote
Power Levels:
Timing
Fuel Load Timing:
Low PSI Timing Reduct:
Timing Reduct Scaling:
Light Throttle Timing Adv:
Timing vs rpm
1500:
2000:
2500:
3000:
Timing Max:
Wiretap
Pump Stretch:
TPS Pump max:
TPS Pump Min
Pump Low Boost Scale PSI
Boost Scaling:
RPM Limit:
Power Reduction:
0 PSI %:
1 PSI %:
2 PSI %:
3 PSI %:
4 PSI %:
5 PSI %:
6 PSI %:
7 PSI %:
8 PSI %:
9 PSI %:
10 PSI %:
11 PSI %:
12 PSI %:
13 PSI %:
14 PSI %:
15 PSI %:
16 PSI %:
18 PSI %:
20 PSI %:
22 PSI %:
24 PSI %:
26 PSI %:
28 PSI %:
30 PSI %:
My Mods
My Tunes
DD:
Quote
Power Levels: 6
Fuel Load Timing: 2
Low PSI Timing Reduct: 2
Timing Reduct Scaling: 100
Light Throttle Timing Adv:2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Fuel Stretch: 1700
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 8
Boost Scaling: 40
RPM Limit: 3500
Power Reduction: 15
0 PSI %:84
1 PSI %:84
2 PSI %:85
3 PSI %:86
4 PSI %:87
5 PSI %:88
6 PSI %:89
7 PSI %:90
8 PSI %:92
9 PSI %:94
10 PSI %:96
11 PSI %:98
12 PSI %:100
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Tow:
Quote
Power Levels: 6
Fuel Load Timing: 1
Timing vs rpm
1500: 16
2000: 19
2500: 24
3000: 26
Timing Max: 27
Fuel Stretch: 1400
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 5
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:92
1 PSI %:92
2 PSI %:94
3 PSI %:96
4 PSI %:96
5 PSI %95
6 PSI %:95
7 PSI %:96
8 PSI %:97
9 PSI %:98
10 PSI %:99
11 PSI %:100
12 PSI %:102
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Race:
Quote
Power Levels: 6
Fuel Load: 1.5
Low PSI Timing Reduct: 3
Timing Reduct Scaling:100
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Quote
Fuel Stretch: 1800
TPS Pump max: 100
TPS Pump Min 20
Boost Scaling: 40
RPM Limit: 3700
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
Quote
Power Levels: 6
Fuel Load Timing: 2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 0
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
Edited by Me78569
  • Replies 1k
  • Views 325.4k
  • Quadzilla Power
    Quadzilla Power
7 hours ago, Me78569 said:
says monster pump
damn i really wonder what the sovp record is. might give me something to shoot for lol
800 some on fuel.  with nitrous, even the HO pump will break 1k
im looking without nitrous, anyone can spray an extra 200hp. but 800 would be impressive. i wonder what the set up is
Top feeds, large compounds, and large injectors.
i would assume is not small turbos and small injectors
I don't think many know specifics.  You can roughly guess what they're using.  It's the same as everyone else who is making good horsepower.  They usually don't just give out their setups willingly.
Edited by trreed
22 hours ago, Me78569 said:
Yes and less than stock.  Again the edge maxes out timing at 32* and it holds the hp records.
Is that Stainless Diesel?
Thank you gentlemen for all the great info! Got the Quad for Christmas. Have my daily tune dialed in pretty good. Have a tow tune I got on here from ME. Will fine tune that the next time I take the travel trailer out. This month or next hopefully. Mopar man I hope you’re getting better and doing well!
  • 2 months later...
I am trying to create my economy/ daily driving tune with some decent passing power and lower cruising egts. Right now my egts are running 650-750 at 70mph. They are a little lower at 65mph but the highway that I mainly travel on (115 miles round trip 5 days a week) is 70mph and if you ain’t doing that you’ll get run over. Now I live in Kentucky where the longest stretch of straight, flat road is about a mile long and I know that probably has some effect on this. But right now this tune is running very smoothly and has the passing power I like but I want to lower my egts and if that means sacrificing some power, I’m fine with that. Main goal is better MPG. Also I don’t have excel on my computer cause I’m not paying 140$ for it. So any help would be appreciated. Also I have 3.73 gears and running 305/12.5/16’s. Here is my tune. I’ve messed around with the light throttle timing adv. (adjusting it to 1.5 and up to 3.5) but it seems to surge while throttling light when shifting from 3rd to 4th
Power Levels: 10
(usually kept on levels 4, 5 and 6)
Timing
Max Load Timing Offset: 2
Timing Reduct Scaling: 100%
Light Throttle Timing Adv: 2
Light Throttle Timing Load Limit: 30%
Timing vs rpm
1500: 15
2000: 18
2500: 21
3000: 23
Timing Max: 24
Wiretap
Pump Stretch: 1600
TPS Pump max: 85%
TPS Pump Min: 20%
Minimum Pump Tap Fueling Percentage: 0%
Pump Low Boost Scale PSI: 0%
Boost Scaling: 30psi
RPM Limit: 3400
Power Reduction: 15%
PSI %: 100
PSI %: 102
PSI %: 104
PSI %: 106
PSI %: 108
PSI %: 112
PSI %: 115
PSI %: 118
PSI %: 121
PSI %: 124
10 PSI %: 125
11 PSI %: 126
12 PSI %: 127
13 PSI %: 128
14 PSI %: 129
15 PSI %: 130
16 PSI %: 133
18 PSI %: 135
20 PSI %: 140
22 PSI %: 145
24 PSI %: 150
26 PSI %: 150
28 PSI %: 150
30 PSI %: 150
Might look at my tune and see what you'll get. My last tank was 20.3 MPG. Twisting enough torque to spin the tires if you get too deep into the throttle passing. Lots of power. The top end come up flat which is fine it is holding the EGT's down to mere 1,100°F to 1,200°F but you already wound up when it flattens out the power. I've not quite released this yet still cleaning up the tune more.
iQuad-Economy-2019-04-05-07.30.5845649020.json
We are gonna need to know what load you are cruising at and at what rpm.
honestly 650 egt at 70 with 305 tires is pretty good.
@Mopar1973Man I will download your tune as soon as I can and see what happens. Appreciate that.
@Me78569 I have no way of data logging for myself since I do not have excel. I only had excel for like a week cause it was a little promotion but now I have to pay for it to even use it
open office or libre office read csv files without issues.
You can watch the screen when you drive though and see what load % is and rpm you are at.
You can't set your timing curve for cruise state vs accel without knowing where to flip the timing curve,  which is this setting
Quote
If you are cruising above that load % then you are never getting higher timing to promote good mpg, if you never go above that % while trying to climb a hill then you will note lower power.
Edited by Me78569
I'm using Libre Office which comes with Ubuntu Linux 18.04. No longer a fan of Microsoft products. :linux:
https://www.libreoffice.org/
Light throttle timing should be based on your flat highway running at a MAX of 65 MPH. Take note of the engine load you want to add maybe 1-2% more than your flat highway engine load. Anything below 65 MPH should hit the cruise timing. Don't attempt to set for speeds higher this will lower MPG number. Anything above 65 MPH should be on the performance timing, not cruise timing. My typical engine load at 65 MPH is 20% I've set my last tune for 22%. 55 cruise load is 15% to 17% which is awesome and can easily keep the cruise state for speeds less than 65 MPH. Idle engine load is about 11% to 12% only 5% more than idle to keep rolling at 55 MPH I've noted instant MPG at about 24 to 26 MPG.
My truck wanted high timing at 70 and 75 mph.  If I dropped timing my mpg also fell.  dunno if it was injector size or what, but point is try both ways and see how the truck responds.
If I stuck timing at or around 20* at 70-75 the truck would do right at 20 mpg
2
Interesting...
Back to the OP make sure to log you MPG's and base your adjustments on MPG records.
I think it was your VGT turbo which dropped the boost low at cruise speeds allowing for the timing to make up with the lack of boost. Where most of us with normal turbos are already in the boost pressure at 75 MPH and bove and need to cut timing back do to the boost pressure aiding in the ignition quality.
