- Replies 24
- Views 4.3k
stevens cummins 13 posts
Mopar1973Man 3 posts
dripley 3 posts
Dieselfuture 2 posts
Ok guys as some know I had to install a re man nv5600 last October, just recently I have a issue with 4th popping out randomly, excessive noise in neutral with the clutch relieced, a small thunk when changing gears, and now the out put seal between the trans and transfer case is leaking, does t th is sound like a major failure conning on in the trans
