- Replies 8
- Views 4.9k
Me78569 2 posts
98whitelightnin 1 post
01cummins4ever 1 post
Silverdodge 1 post
Popular Days
Unless you are going to retrofit OEM LED setup don't bother. Internet LED PnP lights are %100 garbage. Retrofit good projectors with good zexons and call it a day. Output smokes
The company I work for has freightliners with factory led headlights. They use a reflector and are good light but don't put out any heat, or very little. One of the drivers had some slush splashed up
because i enjoy offroading and know that in certain situations the more light the better so i did this... 3 kc daylighters with 55w hid up top two 32" led bars up front
What do you recommend for LED's and headlight housings? Is there a light/housing combo that you would recommend? I need something that is very bright both short distance and long distance as I do a lot of traveling during the night hours.. Also, they need to perform great during snowy and rainy conditions. Links to products would be preferred.
And no, I'm not a fan of light bars. Let's hear those setups/recommendations!
(Please include any necessary wiring harnesses for setups)
