- Replies 12
- Views 2.1k
Popular Days
We have folks here doing it both ways with success. The only thing I question myself on is how hot is the fuel returning from the head and does it raise the temp of the fuel enough to effect the cooli
mine dumps into the filler neck. It helps mix the two stoke oil if its running and forget to dump it in before filling. I like the fill neck because I think it helps dump some of the heat away from th
At this time of the year fuel temp is not a problem. I see some pretty low fuel temps. It might warm up to +40*F. Like tonight it will be well below zero.
On the fuel module…Is it desirable to have fuel return go back into “collection” basket? If so why?
Am I right in my thinking or am I missing something? As long as fuel is getting sucked up with no leaks and 21 psi with ½ fuel line (at idle, don’t know about WOT yet) doesn’t really matter how return fuel is hooked up to. Other than return has to go back into tank.
If fuel return matters, I can put in back in several ways…using draw straw or the fuel filler hose that has a metal fitting with connection tube or fuel module. But fuel module fittings are 3/8 inch line I think.
(I fixed the sump, no longer leaks and now plugged off and want to abandon sump, so hose is no longer hanging down and routing of hose would be better at fuel module instead at sump at rear of tank).
Thanks
