04 keeps eating turbos
- Replies 15
- Views 3.3k
Cueballtech 5 posts
Me78569 3 posts
AH64ID 2 posts
dripley 2 posts
Popular Days
What are you using to verify oil pressure? If it's the stock gauge and it dropped to 0 that means you were under 6 psi for at least 30 seconds. I'd be worried about a lot more than just t
Yes same minimums. Warm should idle at 20ish and cruise at 55-65 depending on load and ambient temp.
Is what I would chalk it up to. verify you have good oil flow beyond that get AFE to get you a new turbo.
Rebuilt motor in frame, due to dropped valve
New injectors, studs, head gasket, gauges
Holset turbo = failure within 7 days (oil into exhaust side)
Replaced with cheap eBay turbo = excessive shaft play within 14 days
AFE blade runner= 3 weeks starting to show signs of excessive shaft play.... And slight oil blow through exhaust side
This is getting really old....
Replaced oil feed line and adapter at the turbo when I installed the eBay turbo with new ones...
Any advice or help???
Edited by Cueballtech
