Nv5600 becareful who you let build
- Replies 41
- Views 9.2k
stevens cummins 16 posts
Mopar1973Man 5 posts
dripley 5 posts
jlbayes 5 posts
Absolutely. Cody Albrecht.
Both drive shafts, input shaft on the transmission or a new clutch, 4x4 linkages to transfer case if not enough adjustment, and I'm sure some more things. It also depends on how much powe
No sir, I am in Michigan. He is in Texas and yes they will take out of town work.
Becareful who you let build your nv5600 sence mine failed I've manage to get it pulled out, had metal in the oil, pulled the tail housing and found that unit was built with worn out parts, the main shaft nut was put on with a chisel and almost broked and not tight, this unit came from cummins performance parts i got took dont let this happen to you
