ADR9802V2.7 MPG Release Final
View File
This is the final release for the 2.7 V2 tune.  It includes mpg meter and mpg trip meter.   This flash also includes a better handoff of control between the ecm and the Quadzilla.  Run this with the Quadzilla vehicle profile V2 1998-2002 version 2.5
Edited by Quadzilla Power
Changed the Name of the File (Using revisions system for updates)
  • Replies 77
  • Views 27.3k
  • Dieselfuture
    Dieselfuture
    I couldn't believe the few small boost leaks I had after i fixed them how much different it was.
  • app-release.apk   There yo ugo.  the beta app has a tune loading screen that helps tell you what is going on.     The difference beyond that is nominal. either will work fine, the
  • this will migrate to the standard version.  The fueling hand off is nicer.  mpg stuff is pretty dang close honestly.   It uses the fueling duration( amount injected) and rpm to calculate instant mpg.
@Quadzilla Power  I did disconnect my phone from the iquad and connect to the house WiFi and still no luck. I even completely disconnected the iquad from the truck and walked into the house and i still get the same error message. I’m about done with IOS software lol.
@Quadzilla Power:hyper: awesome uninstalling the app and re downloading fixed it.  Now I can access the 2.7 version and see the mpg stuff.  @Me78569 sent me a link showing different ways people have had luck downloading tunes for IOS so I’m gonna give it a try and see if I can download the beta 1.9.42 app and somehow make it work. So far my phone opens up the files like this so im gonna try to send the files to me through my laptop.
Not sure if this is the right spot to post this question.  I’ve been messing around with the tuning lately and came up with an idea. Is it possible to create a “lope tune” for the 2nd gen. I’ve read on a post that it isn’t possible for the vp44 to handle a lope tune and another said it would require a cam and bigger fuel delivery lines from the injectors to the injector tubes. Has anyone came across anything similar to a lope tune or is it even possible. @Me78569 & @Quadzilla Power I know you guys are pros at this any Input?
Edited by Tavo24v
@Mopar1973Man speaking of valve lash I was actually gonna do one tomorrow. Got to looking around and found a heck of a boost leak where the fuel filter used to mount up and it blew the gasket out so I was wrapped up with that today. Truck runs like a top now. :burnout:
Yes it is possible, no you shouldn't do it.  The truck can't be driven with that type of tune and it is pretty dangerous in terms of controlling what happens if you touch the throttle.
@Me78569 I had a feeling it wouldn’t work :(, im assuming it’s common rail fuel systems capable of pilot injection that are capable of lope tunes?
On a side note when I write a reply to someone on a thread like this  am I suppose to @ the person I am replying to?
Not exactly required for Me78569 being he's here every day typically. The @ tag basically sends an email to that person and notification on the site letting that person know he's been tagged in a post.
  • 3 weeks later...
On the vehicle selection lave the "v2 Dodge 1998-2002" profile still shows Version 2.5 under it when I updated my quadzilla box to 2.7 and the app to iQuad1.9.41. What gives?
The only profile that days Version 2.7 below it is "V2 Quadzilla only test2"
The app version is not related to the version under the hood.
Is the device rebooted and connected to the internet before starting hte app?   Did you reselect the v2 1998-2002 profile to check for and update prompt?
I know app and ver underhood are separate but wanted to letcha know I had updated it all.
My tablet with the app is not connected to the internet, altho it was when I updated it. I have never seen an update prompt.
 I have reselected the profile after looking under the quadzilla only option.
Just did a reboot and hooked it up to the net and still nothing prompting me to update any vehicle profiles in that menu or not in that menu.
Edited by rogerash0
When you open the vehicle selection page ont he app it goes to the internet, if possible, and looks for any updates to each profile.  Reselecting the currently selected profile may result in an update notice.
I had this issue a week ago, I didn't think to reboot my device, ended up reinstalling the app only to find it could not connect to the internet to get the current vehicle profiles.  I rebooted and the wifi started working and the new vehicle list appeared with a updated v2 profile.
Taking my tablet inside made the vehicle profiles update. I had it linked to my phone prior, vis wifi, and was surfing the net on the tablet, but never saw the prompt.
There was just one little grey icon to the right on the profile beneath the one I've been actively using, that I had to click to update that (irrelevant ) profile. Once I did that the profile I had been using also got the notification symbol to update, and when I reactivated it, it downloaded the update.
I had never heard of or knew of vehicle profiles needing to update like this before.
Thanks me
  • 1 year later...
Just checked in to see if there were any updates....not sure which version I have but I don't see where to download the file at?  Been a while since I've been online here so maybe you guys changed the location of the files..
