Fuel Canister Drain Valve
Hey guys just wondering if the drain valve is rebuildable?  Mine is leaking out the top. I did notice that the top cover was loose and tightening it helped a little but it still leaks. Can I just get some o rings for it?
Thanks in advance
d
  • Replies 9
  • Views 2.6k
  • SilverMoose
    SilverMoose
    Thanks again.  Guess it's time for a new drain valve.   L8tr D
  • 01cummins4ever
    01cummins4ever
    When I replaced mine a while back I figured it was s good time to add a longer hose on the bottom to cut down on splattering diesel all over, my original drain hose was a liiile short. A longer hose a
The filter canister filter should come with a new o ring for the canister. You might take a look in the parts look up tool here and see whats there. If it has o rings it cant that hard to replace them I would not think. But I have never had a problem with mine to know for sure.
L8tr
D
Yup, replacement looks real easy.  I was just wondering if it could be rebuilt.  Thanks
L8tr
D
Www.genosgarage.com Well priced and you get a free sticker every purchase
Heading there right now for that & a big line kit.  Might as well do that while I'm in there.  Just got my first sticker from DAP.:thumb1:
L8tr
d
When I replaced mine a while back I figured it was s good time to add a longer hose on the bottom to cut down on splattering diesel all over, my original drain hose was a liiile short. A longer hose at least I could get it in a drain pan
