This thread is where I will post updates of my modifications, issues i've had, and potential upgrades I'm considering.
This page is dedicated to @TFaoro, because without him my truck would be bone stock still....
To start off, today my VP died.  It took me by surprise, as it gave no indication there was an issue.  But, it threw Death Code P1691, and that's that.  Good thing it died before I bought tires.
Is DAP everyone's first choice for a new VP?
Edited by trreed
  • Replies 615
  • Views 88.9k
  • That was all him lol. I stood by and provided encouragement.
  • I am jealous of the timing cover. Sure is purdy!!!
  • Yesterday I made a trip down to @TFaoro's shop to put a Fast cooler on my truck and do a pinion seal.  While there I was able to witness his new p pumped truck start up and go back together, while put
How deep does your return tube from this VP/injectors go into the fuel module?
The return from the Fass is plumbed into the old stock supply line, so the return drops right into where that "H" with the check valve was in the stock setup, so directly above the basket.
I doubt it's an issue with your FASS return since the DS5 kit supplies a long enough tube and is all the way at the bottom of the fuel basket. The problem I've run into is that the stock return line from the VP and injectors get's snipped in the process of installing the DS5 and so once fuel levels get a little low, or you park on a decent incline, the fuel will sit lower then the stock return line is, so it'll allow air into the system. This might be what you're experiencing but maybe not. Just figured I'd share my findings so it might make it easier for you to figure out yours. I can post pics later if that'd help.
Interesting. I didn't think about that. Though this issue happens at any fuel level. I'm starting to wonder if I poked a tiny hole in the supply line the last time I had the bed raised, since it's gotta be sucking air from somewhere, and the air separator filter is doing its job well
If air is in the supply side of the system and it's not related to fuel level then that sort of eliminates anything in the tank, at worst, very high up on the supply side so I'd think either the fitting itself, the hose clamp could be loose, or maybe a pinhole in a hose somewhere (which should spray fuel), but either way, finding out what's consistent with your issue should help pinpoint the issue more easily.
Unfortunately, I won't have time to dig into it until this weekend. And here's to hoping the issue will present itself quickly. Though I know it won't. ☹️
Finally got around to working on my sending unit and cavitation issues.  The issue did not show itself, and the hoses looked perfectly fine, so FASS will be getting a call about the issue....  But, I did get my 1/2" return fitting installed, so there's now worry there.  Also, I set a personal best for fuel mileage.  I had an hour commute each way for the past two weeks, and managed to get 18.55 mpg, sitting in stop and go traffic while running the A/C.  I'm pretty happy with that!
Anyways, more on the cavitation when I get the time to call FASS.
Both 2nd gens I own have the Vulcan draw straws with 1/2'' lines. Both trucks have cavitation issues that you can hear and see momentary drop in pressure. It's usually worse with less fuel in the tank and happens more often taking off from a stop or on a turn.
When I first installed the fuel system in the 01 truck I had wild gauge readings. I found I had stirred up lots of dirt in the tank and filter the on suction side became clogged in just a few short miles. This combined with air trapped in the prefilter base caused my wild pressure readings. Installed an air bleed off at the filter head and new filter and solved 95 % of the problem. But like I said both trucks are getting air in the system somehow, you can hear the cavitation when it happens even with half a fuel tank :think:.
I'd be interested to see if you have harder starts now after you leave it parked up hill over night with 1/2 tank of fuel or lower. This would confirm my thoughts on the oem return line being the issue.
@JAG1 interesting to hear that two other trucks had the same issues I'm having....
@notlimah I will see what I can do, but I am currently located in Sterling, CO (read: flat) so the opportunity might not present itself
I was out there last year scouting for my uncles deer hunt. That would be very flat!
Yeah but once you get past the mountains it's so flat that's where they have the school of pancake makining. LOL
@JAG1 are you a flat earther :sofa:, at first when I came across this subject I thought what a joke, but now it seems very possible....
Ether way it's well worth your time looking into it. The rabbit hole goes very deep
Nope, me love mountains and pancakes that have one side thicker lol
Well ether way anyone out there has time to waste, check out flat earth, by the end of your journey it won't fell like a waste, in fact it brought many people to true God and Jesus Christ. Plus everyone deserves to know both stories, and it will answer alot of questions. Put you tinfoil hat on, swallow the red pill and go down the rabbit hole. By the time you come out of it in a year or two you'll have a different look on life, hopefully in a better way. I need to warn you there are a lot of disinfo shills out there so you have to chose your info vizely, take what you need and leave the rest. Good luck, if you have half the brain you'll at least give it a shot. Not trying to insult anyone just trying to help. God bless.
Sorry for going of topic
Alex/ Diesfuture, Real quick because off topic.... do you have a link?
BBHD, want to hear what you find is causing the air/ cavatation
Haha....I think that's for @trreed
On the cavitation issue you want to make sure your return lines go as deep as possible into the basket. Put some notches at bottom of return pipes, just like Mike did on his draw straw. Tried that on my basket before reinstalling it with lines about 2, 3 inches of the bottom, tested in the five gallon bucket. What I found out is diesel fuel foms a lot, which should have been clear to me after watching it foam when you fill up a 5-gallon can at the pump. See if the cavitation goes away with full tank versus quarter of a tank. Otherwise air is getting entrained one way or the other. Also could just be ball and spring in the return side of fass if you're experiencing pressure swing.
As for the flat-earth stuff, there are too many links to list we could start the topic on it elsewhere in the Forum.  There are few channels I can recommend to watch, but boy is it time consuming. I don't want to believe that it's a psyop,  if it is it's certainly a genius one. Here are some channels to look up.  Rob Skiba, Richyfromboston, Eric Dubay, Russianvids, ODDTV, Nicholson1968, Jeranism.
I believe these are good Channels, there are more out there,  but this will get going a lot of people. Be patient and give it time you will not regret it.
Highway to Hell and Stairway to Heaven says a lot on its own.
Edited by Dieselfuture
