- Replies 43
- Views 13.9k
jlbayes 9 posts
hex0rz 7 posts
Royal Squire 6 posts
Me78569 5 posts
Then I come along and just finished my sport headlight relay mod. I need to get photos at night time of the lighting. Not as good as @hex0rz or @jlbayes but at least there is more light than stock hea
I know you don't want to hear this, but.....Unless you are going to retrofit OEM led housings don't bother with LED headlights. Plug and play led bulbs are simply a waste of money. They
Once you find one and get it installed it's hilarious how bright they are. My setup looked liked a second sun coming down the road with everything on. Pictures and videos don't do justice of how bri
I'm bound and determined to go LED. I can get the LED bulbs but many people highly recommended projector headlight housings. This is where I'm falling short. I don't know much about them and whether or not I can get a housing that will allow me to accommodate for them. My truck currently uses a 9004 bulb so that would be the plug I would want to shoot for. I guess it really would not matter? Looks like the harness for the bulbs don't have much of any kind of specific plug for them. I think the bigger issue is the bulb style mounting in the housing.
Another thing that gets me is that it appears the projector housings use a separate bulb for low and high. I can get dual projector housings as that would be the whole reason in getting a projector housing in the first place! Why would I want to handicap myself with an old style bulb on low beam and then have a projector lens on high? I want bright light ALL the time! Obviously, I just don't want it in oncoming traffics faces.
Does anyone have experience in this area? I'm not interested in retrofits or DIY, per se.. I just want the bulbs, the housing, wire the dang things up and have some real headlights for a change! The headlights I have now practically need buffed every year and even spending top dollar on the best bulbs I can get off the shelf just don't cut it for me anymore. Living on this rural county road has helped me net some pretty close calls in just the couple years I have lived out here. Getting that light down the road will certainly help me see them sooner if they are out there!
BTW, I also placed an order for a 52" LED light bar and 'am going to use that in my country road driving arsenal! Heck, I've even been blinded out by the local sheriffs using their light bars. Time to smarten up!
