Help Diagnosing Brakes DRAGGING
- Replies 14
- Views 11.6k
Florin1 4 posts
IBMobile 3 posts
Mopar1973Man 2 posts
beren 1 post
Check the Hydroboost for slow or incomplete pedal return: 1. Run pump at fast idle. 2. Pull the brake pedal rearward with approximately 10 lbs. force and release. Measure the distance to the
I think people from CR form come here to educate them self so they can go back to CR forum and educate other people
I have not flushed power steering. IBM I'll try those steps when I get home. Such better tips on this site versus CF. haha.
Hey guys. Think I'll start a new thread in my current issue. I'm chasing down my dragging calipers issue. I thought my initial problem was from my 5th wheel, but it's obviously not. That thread is here
So here is the problem I'm experiencing. My front brakes drag hard. To the point where I can spit on my rotors and have the spit sizzle off. This is just under normal driving with very light brake application. Mostly highway.
I thought I had siezed calipers so I serviced the truck this weekend only to find problem still there.
Here's what I replaced. Bought new front calipers and pads, new rotors, and new brake lines, and on the rear I got new cylinders. Also new fluid flush. Bled brakes once I was done. Bedded new brakes properly.
After two days of driving, I noticed I am still dragging. I'd like to get to the bottom of this before I screw up my new brakes.
Heres my initial diagnosis. I notice if I depress my brake pedal, the pedal comes back up kinda slowly. It doesn't just snap back. I can also see my tail lights stay on for a second or two after I release brake pedal. With the truck off, I pumped the pedal a few times and hold it down with moderate pressure and then start the truck. Pedal sinks a little further, but doesn't "push back". That's as far as I made it. Thoughts? Thanks.
